02-07-2020, 07:42 PM | #1 |
Rep 1,984
Max negative camber?
How much negative camber can you get without adjustable toe links and lowered on MS springs? I have -1.9 and rubbing with 295 30 20 MP4S and a 20 x 11.5 et37 wheel.
I am wondering if I can even get away with that setup relying solely on camber? And if so do I need toe links to achieve it? |
02-09-2020, 09:50 PM | #2 | |
6586
Rep 5,305
That being said, you won't be able get a 20x11.5 +37 and 295/30/20 PS4S to work without rubbing; even with max camber. Dubsesd uses a 305/25/20 PS4S on a 20x11.5 +37 rear wheel. He claims no issues. So you could do that or go super stretch stancebro with a 285/30/20. |
02-10-2020, 08:58 AM | #3 | ||
Rep 1,984
If you say I won't clear even with max camber then I'll stop trying. |
02-10-2020, 12:12 PM | #4 | |||
6586
Rep 5,305
A lot of people say they have "no rubbing", but I found that they mean different things. Some people mean they don't rub while static. Some mean they don't rub the fender but rub the liner on full compression. So I don't really believe anyone when they say they have "no issues", especially when I know the specs I have rub. My rear set up is 20x11 +36 with 295/30/20 PS4S and RE71R, -2.4 degrees of camber, and zero toe. I don't get audible rubbing noises in the cabin but I do rub the fender liner on full compression. I know this because of the marks left on the tires. A 20x11.5 +37 is very similar to my set up; the tire will stay in the same offset but the bead will be stretched another 1/4" on each side due to the wider rim. I hope this gives some insight into my experience and how I determine whether things will fit. It all comes down to offset, width, tire, camber, toe. |
f80er2056.00 |
02-10-2020, 01:49 PM | #5 |
Rep 1,984
Seems to be rubbing on the liner but also it seemed to rub on the edge of the arch as well because the paint is gone there. Whether the paint shop missed that or it was rubbed off I do not know. I put some painters tape on the spot in the liner where it was rubbing to see exactly what its doing and will snap some pics when I take the wheels off later today. 'No rubbing' to me means no rubbing but you are right people interpret things differently.
Do you have adjustable toe links? I was going to buy them just to make all of this easier and for the cost of $250 its seems like a no brainer. Going from -1.7 to -1.9 made it better so I would think adding more camber could possibly eliminate it all together (at least the noise). |
02-11-2020, 08:20 AM | #7 |
Rep 1,984
02-11-2020, 10:18 AM | #9 |
Rep 1,984
02-11-2020, 10:20 AM | #10 |
Rep 84
02-13-2020, 11:32 PM | #12 | |
6586
Rep 5,305
I ended up getting -2.3 degrees of camber on the rear with toe-in 1/16". |
f80er2056.00 |
02-14-2020, 09:50 AM | #13 | ||
Rep 1,984
I did get the toe arms but haven't installed them because my car was back at the body shop. I should be getting it back today and hopefully back for alignment sometime next week. FWIW there is a barely used set of toe arms for sale in the classifieds for 210 shipped. I paid 252 from IND. |
