03-05-2020, 05:25 AM | #1 |
Rep 291
Lowering 2cm the car, steering move very easy on comfort mode
I just lowered a little bit my car, around 2cm, i used st suspension springs(made by kw), front springs seems to be progressive not linear, i like how my car drive, now if i select comfort mode on steering wheel i can really feel the difference, is really comfortable. Before lowering car steering was almost same on sport and comfort mode.
Springs can make differences in steering or it could be related to lowering and different angle to steering gear box? One more thing, st springs kit made by kw came with new bump stops(smaller) included in price, around 180-200euro in Europe. https://www.st-suspensions.net/produ...%5B164%5D&ag=0 Front springs are not same like in website photo, are progressive not linear. |
03-05-2020, 01:12 PM | #3 |
Combined Applications Group
1061
Rep 654
the only thing which can explain this is as you lower the vehicle the front camber changes, putting less pressure on the exterior of the tires, and more pressure on the interior. You will have a very very sligh contact patch difference which will affect the steering feel.
03-05-2020, 03:24 PM | #4 | |
Rep 291
03-06-2020, 06:34 PM | #5 | |
Rep 1,584
Also, I've noticed on cars with thrust bearings above and below the springs, the steering wheel turns much more easily and freely while the car is stopped. I keep a couple sets of those at my shop because every once in a while a customer brings in their own coilover kit and it ends up with spring bind (tends to be the Japanese brands that are a little overly racy for the road) and we find that adding in the thrust bearings not only gets rid of the noise, it also makes steering at low speeds smooth. |
