03-25-2020, 10:48 AM | #1 |
Rep 376
TSB for update 5 bolts upper strut mount
I heard today that there is a TSB to update from 3 to 5 bolts the upper strut mount. I am getting camber plate which is 5 bolts.
After searching could not find TSB. Can somebody share? thank you! |
03-25-2020, 01:43 PM | #3 |
Rep 6,733
Not sure I follow. Are you saying that BMW is going to retrofit all 3 bolt to 5 bolt?
That would involve some drilling and suspension plate hardware. What would be the reason? |
03-25-2020, 02:21 PM | #4 | |
BimmerPost Supporting Vendor
8312
Rep 18,880
Not aware of any TSB, but BMW made the switch from 3-bolt to 5-bolt on M3/M4 in 1/15+ production.
03-25-2020, 02:48 PM | #6 | |
8312
Rep 18,880
We ask all the needed questions when ordering from us to make sure you get the correct parts.
03-25-2020, 02:51 PM | #7 |
Rep 376
My car was produced in 2014. I plan to install camber plate and was told all F82 had 5 holes so it wont be an issue getting camber with 5 bolts. Seems like it could not be the case. I also realized the strut aluminum brace would have additional holes.
rborane241.00 |
03-25-2020, 03:03 PM | #8 | |
8312
Rep 18,880
Most likely you'll need 3-bolt but verify under the hood to be 100% sure.
03-25-2020, 03:46 PM | #10 | |
8312
Rep 18,880
Companies like Ground Control (which we use) and most respected Coilover manufacturers will offer 3 or 5 bolt setups.
