04-05-2020, 09:27 AM | #1 |
Rep 76
Headlight Coding Question
Has anyone used the BimmerCode app to turn off the tiny amber light in the headlights? (USA spec car)
We have pretty much coded everything else but this one seems to elude us, thanks! Last edited by Petepacman; 04-05-2020 at 12:26 PM.. |
04-06-2020, 07:22 AM | #2 |
Rep 242
04-06-2020, 12:52 PM | #3 |
Rep 7,588
Here is another example where someone may get incorrect information by not supplying their model & model year. The communication bus for the f06/f12/f13 changed throughout the production run.
The early models used the FRM (footwell module) for control of exterior lighting...then it changed to the FEM (front electronic module)...then latter models have the BDC (body domain controller) Depending on your build date/model year...you may not find that coding shortcut in Expert Mode when the app reads your control modules. The shortcut given works if you have the FRM control module...but if you have the BDC or FEM...it may not work. BE CAREFUL when using expert mode.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
HeyKC101.50 TinCanSailor650.00 |
04-06-2020, 03:06 PM | #4 | |
Rep 76
04-06-2020, 03:54 PM | #5 | |
Rep 7,588
Thanks for the model year info. I believe you do have the FRM module. If you have the BimmerCode app...you can simply open the app and let it read your modules...and you’ll see which one you have (FRM, FEM, or BDC). If you don’t have the app yet...you can use one of the online part database sites like www.realoem.com . If you input the last 7 digits of your VIN then pull up the diagrams...go to the diagrams for VEHICLE ELECTRICAL (I think it is category 61)...scroll down to the control module diagrams and see if it has the FRM (footwell), FEM (front electronics module), or the BDC (body domain controller) listed. When you use your ‘VIN to pull up diagrams...the database becomes specific to your cars options/build/etc.
04-06-2020, 07:32 PM | #6 |
Rep 76
04-07-2020, 01:57 PM | #8 | |
Rep 318
Man you have a ton of awesome knowledge. I didnt even know you could code this bit out! |
06-10-2020, 10:38 PM | #9 | |
Rep 360
Is it possible that this may be different for LCI cars? Thanks!
06-10-2020, 11:35 PM | #10 | |
Rep 242
LJohnson32219.00 |
06-11-2020, 09:36 AM | #11 | |
Rep 360
06-11-2020, 11:13 AM | #12 | |
Rep 242
I cant remember exactly what I have done to turn it off it was awhile ago. Let me check my car. Try to change them to soft then code and then go back to not active and code. Last edited by M6Roar; 06-11-2020 at 12:01 PM.. |
LJohnson32219.00 |
06-12-2020, 10:28 AM | #13 |
Rep 360
Let me know what you find out. I'd love to find a way to isolate only the angel eye LED's when unlocking the car. Love the way it looks when its dark out, the amber is really cramping the look
06-12-2020, 03:24 PM | #14 |
Rep 11,891
Is there coding to enact rear fog lights switch?
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
12-03-2020, 11:14 PM | #15 |
Rep 76
Any update on this? I have a LCI car now and will be coding it this weekend
12-04-2020, 08:47 AM | #16 | |
Rep 360
I would reach out to them to see what they would charge. I had to have my IHKA / Climate Control modules "re-flashed" since I swapped the units for the ones with ceramic knobs. This plus the headlight coding worked out to be $125 total so I'm sure you could get the headlights done for less. Much cleaner look with them coded off, I love it personally. Steve @ CodeMyBimmer was great to work with!
12-04-2020, 11:29 AM | #17 | ||
Rep 7,588
Now if you've selected to turn off your side markers to where you only see them when you are using your turn indicators...then you'll probably need to code your sidemarkers back on.
12-05-2020, 06:15 PM | #18 |
Rep 76
Qsilver7
I checked the website and put in my VIN but it still says FRM which is strange because I have a 2017 LCI. I tried the same code in expert mode to turn off those ambers but it did not work this time. Any help? |
12-06-2020, 09:43 AM | #19 |
Rep 360
I followed these same steps as well prior to paying CodeMyBimmer.ca guys to do it for me -- everything that logically pointed to the ambers being coded out within BimmerCode didn't work for me. My car is LCI also
12-06-2020, 09:17 PM | #20 | |
Rep 7,588
Lighting will either be in the FRM, FEM?, or BDC control module depending on build date and communication bus set-up you have. You can scroll through the app to see all the things codeable in the app when it’s connected to your car. You won’t hurt anything by looking at what’s available. The only time changes occur is when you select a change the click the CODE button. Until you do that the app won’t do anything to your car. Again, read your bus then select the control module that controls your lights,. If you want to select angel eyes for Welcome Lights for when you unlock the car...that should be on the easy side. In regards to turning off the little amber light in the headlamps...I’m not familiar with that coding because its not something that interested me...so i never followed those coding parameters. I don’t know if tha is on the easy side or the EXPERT. MODE side.
12-07-2020, 11:08 AM | #21 | |
Rep 360
12-16-2023, 03:42 AM | #22 | |
Rep 20
side indicator BMW F12 2011
Tags |
amber, bimmercode, coding, headlights |
