04-10-2020, 09:19 PM | #1 |
Rep 174
DSC light coming on with square set up
Hello, Im currently running 275/35R19 square set up. I noticed when im making a long sweeping turn, the traction control light would start flashing, but I can't tell if its actually kicking in or not. I don't recall this happening on the stock set up. Was wondering if this is normal for running a wide front set up.
04-12-2020, 08:10 AM | #4 |
Rep 351
The traction/stability control on our vehicles is pretty sensitive so the change in front diameter is likely having an effect on DSC. When the system senses differences in wheel speed (due to different size/tire pressure/or actually slipping) it will intervene. Some claim the car will "learn" the new sizes and not intervene as much, but I have only run stock sizes on the F80. Surprised you are able to fit a 275/35/19 up front without rubbing?
04-12-2020, 12:14 PM | #5 |
Rep 20,742
Drives: 2021 911 turbo
The issue is not really the "wide" front tires, but the "tall" front tires.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
