04-14-2020, 03:55 PM | #1 |
Rep 1,015
TC kline DA coilovers and coil bind
Anyone getting bottoming out in the front due to coil bind? I have 350lb/in springs in the front and im at 4 clicks from full soft on compression. Noticed it on the highway when i hit a sharp sewer cement edge sticking out a little bit(like a 2" step). I would imagine it would be more apparent in the 300lb/in front kits they currently sell now.
I can see the marks on my springs indicating full compression. Gonna see if increasing bump 1 click will help but wanted to know if anyone else had experienced this. The recommended street settings are 2 clicks from full soft. Thanks. |
04-16-2020, 01:17 PM | #2 |
Rep 5,961
How much have you lowered the front? IIRC, TCK DA front dampers have less bump travel than most dampers (e.g., MCS, JRZ, Moton, etc.). I doubt you’re experiencing coil bind; instead, you’re likely hitting the bump stop. The effective spring rate ramps up rapidly to “infinity” when you hit the bump stop. Try moving the bump stop to the top of the piston rod (i.e., upper spring seat on camber plate). After driving check to see how far down it has moved on the piston rod and whether it is contacting the top of the strut. If it is then you’re riding on the bump stop. The F 350 lbf/in VVS spring probably has at least ~5” of travel before it coil binds.
hC1001610.00 |
04-16-2020, 07:24 PM | #3 | |
Rep 1,015
Im gonna try trimming the bump stops. |
04-16-2020, 07:38 PM | #4 | |
Rep 5,961
04-17-2020, 10:30 AM | #5 |
Rep 1,015
Its a 7" spring. I think your right and my initial thought that i was bottoming out on the bumpstops were correct. The front struts look like they need to be shortened if i want to drop the car more than 3/4". I understand keeping the height close to stock is better for suspension geometry but 3/4" isnt asking a lot. Will take a pic of the loaded strut and spring. I have about 1 1/4" of shock travel b4 the bumpstops make contact.
04-17-2020, 11:06 AM | #6 |
Rep 1,015
Im gonna trim the bumpstops 1/2". The springs do look like they have a little more travel then the shock. Heres some pics of the loaded spring and wheel gap:
Thanks again. |
04-17-2020, 06:58 PM | #8 |
Rep 1,015
I did. Read post 3. I told them i was bottoming out on the bumpstops and if it was okay to trim them. They said i wasnt and it was coil bind. They recommended i dont hit bumps or buy 400# springs. It didnt make sense to me because i wasnt getting coil bind when the car was 1/4" higher.
Anyways, im going to trim the bump stops 1/2". |
04-17-2020, 07:15 PM | #9 |
Rep 5,961
Definitely looks like you’d hit the bump stop before the spring tuns out of travel. However, be careful, the Koni dampers have limited travel. You don’t what the internal shim stack contacting the bottom of the strut.
04-17-2020, 09:26 PM | #10 |
Rep 1,015
I agree, i've heard of other ppl destroying the internal shims because they removed the bumpstops which was why i wanted to double check with TC Kline but they did not believe me... Maybe i will start with trimming 1/4" off and see how it feels.
04-18-2020, 07:24 AM | #11 |
Rep 5,961
I’d recommend marking where the bump stop is on the piston shaft, remove the bump stop and then compress the piston rod to see how far it compresses. Then measure the distance between the original and compressed marks to the top of the strut. That’ll give you the max piston travel and then you can determine how much of the bump stop to remove. Also, remember the bump stop will compress before reaching its max stiffness. I’d conservatively assume at least a 1/4” of compression.
hC1001610.00 |
04-19-2020, 01:00 AM | #12 |
Libertarian
71944
Rep 4,035
This is the reason why i wont buy TC Kline products anymore, i had this very issue with my E92 M3.
You can buy the black and yellow radial bearings from GC and hat, that'll fix your problem! TC's camber plates dont come with radial bearings, only come spherical bearings. You need both spherical and radial bearings for the camber plates to work properly. Vorshlag and GC camber plates come with both! |
04-19-2020, 08:15 AM | #14 |
Rep 1,015
04-19-2020, 09:58 PM | #16 |
Rep 5,961
You’re definitely lowered more than 3/4” on the front. It looks like there’s about 1” of piston travel before the bump stop contacts the top of the strut. With TCK Koni dampers you’ll need to run higher spring rates if you want to run that ride height. I’m not sure a 400 lbf/in spring will solve the problem at that ride height because it’ll reduce dynamic displacement by only 12.5% compared to a 350 lbf/in spring. A 500 lbf/in spring might not be enough - it’ll take a 500 lbf dynamic load to hit the bump stop. For a ~3,600 lbm car, it’s possible to develop a 500 lbf load per corner which is only a ~0.5 G vertical acceleration.
hC1001610.00 |
04-19-2020, 11:51 PM | #17 | |
Rep 1,015
Here is a pic of stock suspension(non ZCP) for reference: Last edited by hC1001; 04-20-2020 at 12:23 AM.. |
05-02-2020, 04:17 AM | #18 |
Rep 1,665
Why do people want good ride quality, then choose light spring rates, then slam the car and expect the suspension to somehow defy the laws of physics?
What I have found is it is best to only modestly lower the car and, seems counter-intuitive, but running higher spring rates often IMPROVES ride quality b/c it keeps the car off the bumpstops. As M3SQRD states, once your car runs out of suspension travel, spring rate basically goes to infinity. So if you're really going to drop your car that low, step up to much higher rate springs to keep the car off the bumpstops. When you've slammed the car, trimming the bumpstops 1/4" or 1/2" isn't going to keep the car off what's left of the bumpstops. If you want to have your car slammed that low, get bags or have your shocks properly shortened so that you can get back some suspension travel. I doubt TC Klines are designed to be slammed that low. Just because the threads on the coilover lets you slam the car over 2" doesn't mean it's a good idea to do so. |
05-02-2020, 10:44 AM | #19 | |
Rep 1,015
TC Kline instructions are to adjust front height and leave at least 1" of space between bumpstop and top of strut. I have about 1.25" of space. The issue is with the design of the setup. It would've been better to shorten the struts by an inch. |
05-02-2020, 11:58 AM | #20 |
Rep 792
That definitely seems like not enough travel before you hit the bump stops? They sell the kits like this? Have there been any other issues? I am in the market for coilovers, and was just on their site the other day
05-03-2020, 01:51 AM | #21 | |
Rep 1,015
This TCK DA coilover kit was one of the earlier versions . 60mm 350#F and 2.5" 600#R, rear rebound is not adjustable without disconnecting the rear shock mounts and there is also knocking noise from the front struts at low speeds. Ive owned bilstein pss9, h&r, and kw v3 coilovers on other cars and the dampening is really good on these shocks. Its true these shocks can be setup comfy like stock with little body roll. I also think the stock non edc suspension is great on the car too. Havent gotten a chance to try the TCK coilovers on the track due to covid19. Last edited by hC1001; 05-06-2022 at 12:32 AM.. |
MAddict42.50 |
05-03-2020, 02:46 AM | #22 | ||
Rep 792
