05-06-2020, 07:18 AM | #1 |
Rep 161
F10 m5 rotors on f15 50i
What's up guys, I picked up a set of f10 m5 calipers and will be doing the swap here soon on my 2014 50i. Does anyone know if you can use the 400mm f10m5 rotors instead of the 395mm f85 x5m rotors? I searched the brake swap thread on here couldn't find a solid answer. I still have to get the conversion brackets from that ebay seller tronik , unless someone has a better place to get them.
The f10 rotors are not only 5mm larger but they are lighter as well. Another reason is they have a few aftermarket options available that are significantly cheaper than the oem rotors. Also to my knowledge my stock 50i calipers will work with the f10 rear rotors I just need the oem f10 caliper brackets correct? Thanks |
