05-22-2020, 08:05 PM | #1 |
Rep 4,203
Alex@Alpinemss
Another 2nd hand M4, another coding job done by Alex the master....log in, boom done. He did my first M4 years ago...glad he is still doing this. Beats doing the Bimmercode dance like i did on the M2.
Thanks Alex GTS EPS (Electronic Power Steering) *Stiffens steering for better control/handling with more advance power assist. GTS Traction Control *Givens more slip in MDM and allows better traction control settings GTS Differential *Allows for better take off from the line and better control on turns. No Dazzle High Beam assist (for cars with LED lighting package only) YouTube Video of Feature Adaptive Headlight 2 (Variable Light Distribution) Removal Of Seat Belt Chimes Removal Of Seat Belt Warnings Windows up/down with key Windows up with comfort access (Comfort Access Required) Folding Mirrors with key (hold to fold on lock) Folding Mirrors with comfort access hold to fold on lock) YouTube Video of Feature Unlock doors when engine is turned off (Single pull on door handle) Radio/iDrive shutdown when car is turned off and door is opened Remove window safety feature (windows will not stop rolling if door is opened) Remove Amber Side Marker Lights in headlights Auto Start/Stop feature default to off or memory Flashing Brake Lights (Brake Force Display) (Upon hard braking the brake lights will flash) Door handle LED on in reverse Increase Ambient Lighting (standard 60%) Disable Headlamp Washers Taillights as Daytime Running Lights Removal of iDrive Accept Warning (faster boot up after removal) Activate DVDinMotion (Play Videos on the go and stopped) Activate Video through USB & in motion. (only works with videos on flash drives. Does not work with videos on your phone) Office in motion Full text message display in Office (standard 3 line preview) Removal of camera warnings (requires cameras) Auto Climate Control off when car is turned on if left off previously Digital Number Display For Tire Pressure Monitor with Temperature Inband Ringtone (transfers the ringtone from your phone) Change gong to Rolls Royce/i3 gong Add Office & Enhanced USB (6NS) to iDrive Display full text message in Office Cameras in Motion (not suggested for reverse camera) Driver seat moves back when ignition is turned off CS EDC |
