06-07-2020, 05:05 PM | #1 |
Rep 845
rear right strut replacement
Hey all,
Bent my rear right strut in an accident, insurance company is only replacing the damaged strut. I have EDC and around 28k miles on the car, should i be replacing my other axle strut out of pocket as well? How much will it run me? |
06-08-2020, 06:46 PM | #2 | |
Supreme Allied Commander
3893
Rep 54,605
Drives: F80 M3
Get a quote locally. The price will vary greatly depending on where you are. |
06-08-2020, 07:00 PM | #3 | ||
Rep 845
06-08-2020, 07:12 PM | #4 |
3893
Rep 54,605
Drives: F80 M3
06-09-2020, 04:02 PM | #6 | |
Rep 845
In fact yes i read the replacement for them is at 140k so maybe i will keep it as is. It is very low miles |
06-10-2020, 08:18 AM | #7 | |
Rep 219
https://www.newtis.info/tisv2/a/en/f...nsion/1LTqEPBe 33 00 ...Information on replacing shock absorbers Situation: When a shock absorber is faulty on one side (leaking, noises, limit values exceeded on the shock tester), often both shock absorbers on the axle in question are replaced. Effect: This is not necessary for technical reasons and causes the manufacturer not to recognize the unnecessarily removed shock absorbers as defective parts. Unnecessarily high costs for the customer can be avoided by replacing the shock absorber on one side only. Procedure: If one shock absorber is damaged, it is only necessary to replace both shock absorbers when the car has driven in excess of 80 000 km. Exception: On all M‐GmbH models, when a limit value is exceeded on one side, it is still necessary always to replace both shock absorbers on the relevant axle. |
06-10-2020, 10:58 AM | #8 | ||
Rep 845
I called and asked and the other one did not exceed the limits hence why the replacement was done for one. I feel if both were out i would have just opted for full coilover set up, these oem struts are expensive. |
