06-18-2020, 03:25 PM | #1 |
Mad Fiddler
802
Rep 1,004
Where’s the Compass?
No, I haven’t dug out the manual - yet. I’ve got a 2016 640 GC and I can’t figure out how to display a compass. Any suggestions? Other than RTFM?
06-18-2020, 06:02 PM | #2 |
Rep 2,286
I just cycle through the 'BC' options and it displays...
IG: project540ix
G30 540i xDrive / Stage 3 via BM3 / xHP Stage 3 / Pure 800 Cast Turbo / 5" Catted Downpipe / MST Intake / Remus Exhaust / MSS Springs / 19" JR SL01 & Conti SC7 / 20" BBS CI-R & Michelin PS4S / F90 Sway Bars & Braces / Lots of Gloss Black |
06-19-2020, 01:32 PM | #4 |
Rep 7,588
I think the OBC options selected by pushing the BC button on the tip of the turn indicator are selectable in iDrive. Go into SETTINGS in iDrive then look for OBC info and click/select for anything that would give you a list of OBC features to select from.
If its not there...if you have one of the newer iterations of iDrive (like NBT)...you may be able to add it (aka CODE it) using BimmerCode or one of the other coding applications/software.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
06-19-2020, 02:09 PM | #5 | |
Mad Fiddler
802
Rep 1,004
06-19-2020, 04:38 PM | #6 |
Mad Fiddler
802
Rep 1,004
There IS no compass.
Went through with bimmercode and dug around in my iDrive and discovered that my car has no compass display. I put my GPS map view into ‘facing north’ mode so now I’ll always know which direction I’m headed.
No auto trunk - no compass. What’s next? |
06-20-2020, 10:25 AM | #8 | |
Rep 7,588
And this was done using EXPERT MODE in BimmerCode. There was also a chart given as to what to do in expert mode. So if you look up one of the BMW coding forums...you should be able to find this info. Another thing a can slightly recall is...the instrument cluster compass was found in the KOMBI module...and the compass (kompass) for the iDrive screen was found in the NBT module. But again, this was being coded using EXPERT MODE which means if you’re doing this...make sure you have it down for sure what you’re doing. Using expert mode isn’t for those that aren’t known for being precise in following instructions.
Frupal802.00 |
