06-28-2020, 03:22 PM | #1 |
Rep 12
Does BMW still sell the n63?
So I had a total engine failure in my 2012 coupe, engine literally exploded and my extended warranty through Mercury is replacing the engine but I’m wondering will I just be getting another N63? Or will I be getting the N63TU? Questions I’m realizing I should’ve asked but my service rep doesn’t seem very knowledgeable anyways.
06-28-2020, 04:41 PM | #2 |
Rep 333
Being that it’s an aftermarket warranty, they may only payout for a new short block and make them transfer any part they determine to be still good. Of course, depending what failed.
When I worked at Jaguar, the factory would never have us rebuild anything, but the after market guys would make us to save a few bucks. |
06-28-2020, 05:09 PM | #3 | |
Rep 12
06-28-2020, 05:31 PM | #4 | |
Rep 285
2015 Bmw 650i xDrive Gran Coupe
M Sports Edition Carbon Wing Carbon Front Splitters Carbon Rear Diffuser Carbon Grilles Powder Coated 373m Triple Bronze CPG intakes Arm catless downpipes Arm charge pipes Custom Snow Performance methanol injection Custom exhaust, straight pipes to quad tips Bootmod3 Stage 2 3.5 Tmaps xHP Stage 3 |
06-28-2020, 05:34 PM | #5 |
Rep 333
Admittedly, I don’t own a 6 with a 63 motor for the reasons you are currently dealing with. I I’m not in the full know of the complete differences between the N63 and the TU. From what I read, it appears that most, of not all, are bolt on items. Fuel injectors, timing chain, batteries and other items related to the cooling system.
My fear is that at best, you will receive a block with cylinder heads and they reuse everything else. I would ask the service manager, not the advisor. And I thought the N62 couldn’t get any worse, then came the N63 Last edited by Derekz4; 06-28-2020 at 05:44 PM.. |
06-28-2020, 05:37 PM | #6 |
Rep 333
These are the differences between a long block and short block.
“They only differ in the components they carry. A short block package typically includes the engine block, crank and pistons. ... A long block engine has all the parts of the short block package. To the skeleton that is the short block, it adds a cylinder head, camshaft and valve-train.” |
06-28-2020, 05:51 PM | #7 |
Rep 12
But they charged my warranty company $15k , is the rest just labor then?
06-28-2020, 05:53 PM | #8 | |
Rep 285
https://bmwtuning.co/bmw-n63-vs-n63t...tu2-vs-n63tu3/ As it stats... almost a different engine and it is.
06-28-2020, 05:55 PM | #9 | |
Rep 285
06-28-2020, 05:58 PM | #10 |
Rep 333
06-28-2020, 06:01 PM | #11 |
Rep 285
N63 was over $20k replacement before lawsuit. Bmw dropped the short block price by over half to 'help'
06-28-2020, 06:05 PM | #12 |
Rep 12
06-28-2020, 11:58 PM | #13 | |
Rep 285
06-29-2020, 01:32 PM | #14 |
Rep 1,602
If it makes you feel any better, I've had two N63s and 1 N63TU and by far the N63s were a lot more reliable with less issues and "drank" less oil. Never had issues with the N63s for years, sold the TU after 1.5 years due to constant need to add oil. I'm good friends with a Service Advisor and talked to him about N63s/TUs, etc. He said that they try to replace some parts with better/newer revised ones. Not sure to what extent.
I feel like BMW added the "new" variants to make the customers feel like they are getting a newer/better engine, when in reality they are euqally crap and just ticking timebombs. Even so, I've come to realize that I'm addicted to the torque and in this case the saying "you gotta pay to play" is spot on. Even the new M550i is still having similar issues. https://www.carcomplaints.com/news/2...-lawsuit.shtml Believe it or not, they use a similar nomenclature instead of coming up with something else. You'd think they'd call it N64 to make people not realize they are not fixing the issues and/or are creating new issues with the new variants. What I'm trying to say is, enjoy your new engine as I'm sure it comes with a warranty. You are in a better spot than having a used N63TU. Last edited by AmooManiak; 06-29-2020 at 01:40 PM.. |
06-29-2020, 02:56 PM | #15 | |
Rep 12
Thanks for this, ugh will have to wait a little longer as I was just told the car was on its final test drive and was rear ended .. so now they have to get the back fixed . I almost want to cause a ruckus about this . |
06-29-2020, 03:10 PM | #16 |
Rep 333
