07-04-2020, 10:45 AM | #1 |
Rep 166
Brake caliper upgrade for std sized discs
Hello,
I am developing with a brake caliper manufacturer a caliper upgrade for the M2/3/4 that will work with the stock size discs. The idea is to use larger calipers front and rear, allowing the use of much larger pads, with a very close to stock piston area front and rear to maintain stock brake bias. STD calipers use very small pads, while the discs are generously sized. The kit would also work with aftermarket discs designed to work with OEM calipers. Would anyone be interested in such a solution? I expect the price to be around £2000/2200 front and rear, ( calipers, steel or Ergal brackets, and lines) + pads. Any interest, let me know |
