ARMA SPEED
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Suspension | Brakes | Chassis
      07-18-2020, 08:45 AM   #1
DavidStr
Drives: F82 M4
KW HAS RIDE QUALITY.less Harsh than OEM CP springs?
Just fitted Version2 KW HAS on my M4 Competition,paired with 10mm spacers front and rear.
I have the impression the suspension is less harsh and a tad softer.
Anyone has the same feeling?
Rear spring rate is according to KW same as the comp pack, while front uses a progressive spring Vs the linear on the stock comp car, so hard to judge.
Just my Impression?
      07-18-2020, 01:59 PM   #2
JamesGames
JamesGames's Avatar
Drives: E60 550i|F82 M4|F48 X1|VA STi
Just my Impression?
Progressive vs linear rate is probably the reason -softer at initial compression.
      07-18-2020, 05:20 PM   #3
DavidStr
Drives: F82 M4
Wonder why both KW and Mperf use progressive front springs.
If I can't find a linear spring for the front I will go back to stock.
      07-18-2020, 05:29 PM   #4
JamesGames
JamesGames's Avatar
For the exact reason you mentioned - "less harsh" - translates to better ride, especially when using OEM shocks. KW club sports are linear. KW Variants are progressive.
f80post
