07-31-2020, 08:38 AM | #1 |
Rep 119
F80/F30 LCI LED Tail Lights
I have a set of LCI LED tail lights off of a 2018 F80 M3 NA spec, I swapped them out for shadowline Euro set. These tail lights are pristine, no scratches, ceramic coated and the car is garage kept. Does not come with drip rails, for upgrade you will still need harness and coding. Can pick up local in Kaiserslautern area or i can ship them USPS to you in USA. |
09-13-2020, 02:42 PM | #3 |
Rep 119
Can ship cheap to US address via USPS. BUMP
careagax5m93.50 |
01-26-2021, 09:06 PM | #8 |
Rep 1
2018 F80 M3 Tail Lights
I recently purchased my 2018 F80 M3 Tail Lights, and I wanted to swap the tail lights for either the shadow or blackline, but I get confused on the forums as some installations are just a swap, while others need coding.
Can you confirm since you recently changed? Thanks. |
02-02-2021, 11:31 AM | #9 |
Rep 119
You have a 2018 which means you will have LED. The blackline and shadowline are also LED so they are just plug and play. The only time you will need more is if you went from incandescent bulbs to LED.
Tags |
f80 lci led, lci, led, tail lights |
