08-06-2020, 11:58 AM | #1 |
Rep 139
Alignment Question
I called a local AAA shop near me to get an alignment quote. He asked if I had lane adapt I think he called it. Assuming he meant the function where it tells you if you've crossed out of your lane.
He said he can't align the car because that system needs to be recalibrated once the alignment is done. Anyone know what he's talking about? |
08-06-2020, 03:38 PM | #2 |
Rep 2,162
I think he's talking about cars with lane keeping assist where the steering is actually affected by lane drift. Ours isn't that and the alignment has no effect on the system since the driver is always in control.
I'd still take it to someone else because he obviously isn't familiar with modern BMWs |
08-06-2020, 03:44 PM | #3 | |
Rep 139
08-06-2020, 03:56 PM | #4 | |
Rep 139
08-06-2020, 07:47 PM | #6 |
Rep 2,162
Some of these grease monkey shops are on a short fuse. Car tech is cray nowadays.
We just brought home a 2020 Volvo XC90 and it makes my F80 seem like an E46 in terms of its gadgetry. Can't imagine how many indys will ever be able to service it. |
08-07-2020, 03:08 PM | #7 | |
Rep 97
08-07-2020, 03:34 PM | #8 |
Rep 1,015
You can perform an alignment on the F80/82 like any other ordinary car. I do my own alignments with strings, camber gauge, and toe plates. It is true that BMWs specify weights in the car and a full gas tank to simulate real word conditions https://www.newtis.info/tisv2/a/en/f...ent/1VnXsie3W9, that info is usually loaded into the alignment machine. I also have BMW diagnostic and coding software in case i do need to calibrate something but really you dont need it unless the shop is so bad they cant find the center of the steering rack. There is also no follow up work after a wheel alignment in the BMW service manual. https://www.newtis.info/tisv2/a/en/f...ent/1VnXs859Gw I strongly suspect its because they spec the steering angle and as long as its in spec, you shouldnt have any problems.
FWIW, id rather have a shop tell me they cant/wont work on the car instead of them trying to and messing something up. Some shops will even warn you that they dont have any idea how to work on your car but will take your money and see if they can... Maybe you can ask the regional forum for recommendations on alignment shops but really any shop with an alignment rack can do it. What makes a good alignment is the technician. A bad one will only align until it shows green on the screen but it can be -1.3 left and -1.6 right. A good one is a technician that takes his time to get both sides even... Last edited by hC1001; 08-07-2020 at 04:16 PM.. |
9M711235.00 freespirit82.50 |
08-07-2020, 10:18 PM | #9 |
Rep 230
this drives me crazy. all green, done. Recently I have started to state that if front camber is one side -1.30 and other side -1.50 i will not pay any money.
08-08-2020, 11:13 AM | #10 | |
Rep 139
