08-13-2020, 07:05 PM | #1 |
Rep 541
My front rotors are rusting in the middle
Hello guys,
New user here. I'm having a problem with my front rotors where they're rusting in the middle as if the caliper isn't pressing there. Can someone tell me what the problem might be? I attached a picture as well. Thanks, Raz |
08-13-2020, 11:11 PM | #3 | |
Rep 541
08-14-2020, 09:37 PM | #4 |
Rep 1,107
The brake pads are not making contact on the rotors in those rust bands. Pull caliper and inspect
'13 Black Sapphire Metallic - BPM Stage 1 Tune - RPI Exhaust - KW HAS Kit - 12mm spacers all around- Carbon Fiber front lip - High Kick Trunk Spoiler - Rear Roof Spoiler - IND Kidney and Fender Grills - 20% Tint all around 50% Front Windshield - PPF
08-17-2020, 05:51 AM | #5 |
Rep 19,960
Brake pads are making contact alright if it's braking ok, take pads out and replace possible faulty pads with new ones and clean up rust with wire brush finishing of with wire wool if it's not a caliper fluid leak, if it was then you'd have warning and soft pedal.Whats in like on the inner side of disc?..the same or ok??
09-13-2020, 11:36 AM | #6 |
Rep 1,254
agreed, something is up there. the contact patch of the pads is way off.
2009 E92 M3 build thread: https://www.m3post.com/forums/showthread.php?t=1754875
Follow me on IG - www.instagram.com/the_driven_enthusiast |
