08-24-2020, 06:57 PM | #1 |
Rep 7
2008 E90 Blown Engine
I'm in NorCal, selling my '08 E90 M3 6MT. 67,XXX Car has clean title and is stock except for modified exhaust. Rod bearings, throttle body actuators, and idle control valve had been replaced. Exterior is in really good condition. Jerez Black. Garaged so paint is still vibrant except for 1-2 chips on hood from road rash. Some minor curb rash on front wheels. Interior is clean with dark grey/black and carbon fiber interior. No wear or rips in seats, carpet, etc, with only some wear on top of steering wheel. Car has all the options packages, cold weather, premium, technology, moon roof, rear sunshade, etc. Blown motor. Car is at a Dinan shop right now with the motor on a stand with teardown to start this week. I was hoping the motor was salvageable, but that's not the case. Once they removed the intake and exposed the valley of the engine there were piston pieces everywhere, and the cylinder head was toast, hole in the upper oil pan as well. If this sounds like an ideal candidate for your project, PM me an offer. Recent photos of car here (pardon the dust from the shop): https://photos.app.goo.gl/q64L3oy7JY7w4RJs5 *Link works now!* *Blown motor update. Not related to the rod bearings at all. Suffered a dropped valve from either broken valve spring, failed lifter or both. Valve met piston and pulverized each other. Motor not salvageable at all. They chalked it up to a fluke and terribly luck. Engine and transmission have been removed, and car is looking for a new home! *Price drop. Roller is ready to be loaded on a truck and sent out. I'm in NorCal in the Bay Area, and will tow it for free up to 200 miles.* Last edited by jackmahoney; 09-10-2020 at 01:08 PM.. Reason: Update on condition 9/10/20 |
08-24-2020, 08:14 PM | #3 |
Rep 659
so blown motor even after rod bearing replacement?
2005 Phoenix Yellow E46 M3 6MT Coupe
2007 Imola Red Z4 M Coupe 2013 Interlagos Blue E92 M3 6MT ZCP CF roof |
08-25-2020, 09:09 AM | #7 |
Rep 10,686
You would have had no trouble getting the $15k before the motor blew. If the replaced rod bearings were in bad shape, maybe they contributed to main bearings failure. Or maybe your motor was destined to suffer main bearings failure no matter what. It’s much less common but still disastrous for those who suffer it out of warranty.
08-25-2020, 06:40 PM | #8 |
Rep 2,145
Drives: 2011 E92 M3
Would be awesome to know what actually failed. What bearings were installed?
2011 E92 M3 - 6MT, ZCP, ZF LSD, ESS G1, Some other goodies... |
08-25-2020, 08:40 PM | #10 |
Rep 743
08-30-2020, 09:30 AM | #12 |
Rep 1,042
Drives: BMW M3 e92 08 & 330d e90 10
Sub'ed to thread for updates.
Sorry to hear of your blown motor
Oil analysis for finding wearing rod bearings?. Collation of oil analysis reports with some rod bearing photos for the M3's S65. My categorisation of pulled rod bearings in the rod bearing condition thread. My updated 'Blown engines' list. |
09-09-2020, 02:29 PM | #13 |
Rep 7
Update- Wasn't the rod bearings at all. Either a broken valve spring or failed lifter or both, leading to a dropped valve.
Valve met piston, and an unstoppable force met an immovable object. Block destroyed, head destroyed, engine totally shot. |
tdott3956.00 Assimilator1595.50 |
09-28-2020, 02:45 PM | #14 |
Rep 1,042
Damn, sorry to hear that .
Thanks for the update anyway!
09-28-2020, 05:21 PM | #15 |
Rep 54
Drives: 2009 M3 E92 6 speed
I feel your pain!!! I had the same issue on my 09 M3. with 75k miles. Loose valve dropped into cylinder# 8. I end up writing a letter to BMW since it was my second M engine failure. They provided a new engine at discount cost at $10k and end up putting a NEW engine for $17K including labor.
It was more expensive but i did not want to deal with bearings, engine top covers, valves, water pump later on.
10-10-2020, 10:20 AM | #17 |
Rep 54
I end up with a 2015 New engine with 0 miles. BMW still produce engine but no more cars after 2013.
03-23-2021, 09:45 AM | #18 |
Rep 1
Hi Jack I have a couple of questions related to this specific vehicle.
Tags |
blown engine, blown motor, blown s65, e90 |
