BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
EXXEL Distributions
      09-13-2020, 11:45 PM   #1
Tad2020
Drives: BMW328i
Misfire and white smoke from engine?
Hi,
I have 2010 BMW 328i sedan.
I got 3 cylinders misfiring, according to Autozone code.
I saw some oil leak around the valve cover. I also saw oil on a few spark plugs: therefore, the problem was the valve cover gasket.
I replaced spark plugs, coil packs, oxygen sensors 1 and 2 upstreams, and valve cover gaskets. After replacing them, I started the engine. The first 20-30 seconds idle seems stable. After that, it starts making noise and misfiring sounds. And also I see white smoke coming out from under the engine. What is this smoke??? After replacing the valve gasket, I do not see any oil leak.
I opened up the valve cover to see again if there are cracks. I do not see them anywhere on the cover.
I have not changed fuel injectors.
What's the problem?
Tags
bmw 328i, misfire
m3post
