09-15-2020, 06:04 PM | #1 |
Rep 419
Am I the only who one who is having an issue fitting a 265/35/19 tires (P4S) on 19x9.5et22wheels with an MP Has in the front? The tire is rubbing on the spring perch. Yes the car currently sits pretty low.
I bought my M4 with a gen1 KW HAS kit and when I tried fitting my new wheels 19x9.5et22 with the tires above I was getting rubbing. My understanding was that with the MPHAS I wouldn't have the same issue. So after buying a brand new MPHAS and another trip to the shop I'm still having basically the same issue. Not sure it was any better. I thought I did my homework. What are my options now? I never realized how tight it was in the front after having zero issues with my 305/30/19 on stock height. I think I'm just going back to stock and solving all my fitment issues. Not sure what else to do... can someone please give me feedback? Will something like a B16 setup give me more clearance? Help please! |
09-16-2020, 03:44 PM | #2 |
Rep 1,566
What's the ride height/location of you front perch. It may be set too low. I run 265/35-19 AD08R which is a huge tire on 19x9 +20 and have zero problems and at least 1/4" or more of clearance
M3nmotion18390.00 erictrainer277.00 |
09-16-2020, 04:12 PM | #3 |
Rep 661
As Knightarmor said, it may be set too low. But, the shop didn't check the clearance after the installations? My MP HAS is set little lower than the recommended ride height and never had any issue, Thanks to Knightarmor!
erictrainer277.00 |
09-16-2020, 04:24 PM | #4 | |
Rep 419
I also just assumed that if he raised it then it would defeat the purpose and I'd be at stock height. Its my first go around dealing with drops and suspension and it has been an expensive lesson. I still don't know what to do... whether sell the MPHAS and go back to stock and springs. Is it correct to assume this will give me more clearance inside? Or just get a full coilover set. |
09-16-2020, 08:42 PM | #5 |
Rep 1,566
You cannot get to stock height with the MPHAS set at the highest setting. From your picture it's clear it is set too low. Raise it up until it clears, and even then that is going to be way below the recommended height.
See the attached photo. I recommend starting here and slowly work your way down. |
erictrainer277.00 |
09-16-2020, 09:34 PM | #6 | |
Rep 20,742
Drives: 2021 911 turbo
Are you sure your wheels are ET22? Worse comes to worse, you could simply add a spacer to improve inboard clearance...
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 09-16-2020 at 10:11 PM.. |
erictrainer277.00 |
09-16-2020, 09:45 PM | #7 |
Rep 1,566
That's gonna be a negative on 5mm lower than stock being the highest, the fronts we set at the highest on one of our ZCP's and it's about 3/4"+ lower than stock unsettled. Never tried the rears at the highest setting.
erictrainer277.00 |
09-16-2020, 10:14 PM | #8 |
Rep 20,742
Indeed, after double checking it is 10mm in front (5mm is for the rear on the M4), I fixed my OP. But that's nowhere near the 3/4"+ (19mm) you mention...
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
erictrainer277.00 |
09-16-2020, 10:36 PM | #9 |
Rep 1,566
Yea that's incorrect for the front and I doubt raising the rear could make that much of an impact to the front height but you never know... I'd really be curious what OP's car looks like in the front with the spring perch set to where he's got it. That's got to be dumped .
erictrainer277.00 |
09-17-2020, 06:10 AM | #10 |
Rep 419
This is what it looks like with my KW and yes can confirm my new wheels are Titan 19x9.5et22. I cannot do spacers because it will rub on the outside fender...I did try that option.
09-17-2020, 03:48 PM | #12 |
Rep 1,566
Yeah you literally just need to raise the spring perch a bit. About 20mm from looking at your pic and you'll clear no problem. Like I mentioned above start with the dimension I posted and work your way down. Give yourself at least 1/4" of clearance gap between tire and perch and you're good to go. Just had my f80 up in the air this morning and I have over 1/2"+ gap between my tire and the perch.
I also in the past have test fitted a 19x9.5 with a +22 offset and 275/35-19 up front and had a good 1/4" gap. |
erictrainer277.00 |
09-17-2020, 04:22 PM | #13 |
Rep 1,397
What size spacer did you try? I ask because I had terrible rub on my track car after the race alignment and coils did a 3 mil spacer to just provide enough clearance. I cant imagine 3 mil would cause your tires to contact your fender and if so, the only solution you should look into is raising it a bit or a combo of the both. if you are in fact that close on tolerances, you are one hard bump or unexpected pot hole away from a nice fender replacement...
09-17-2020, 05:35 PM | #14 | |
Rep 419
09-17-2020, 05:39 PM | #15 | |
Rep 419
09-17-2020, 09:04 PM | #16 |
Rep 1,566
Yea Hard to tell from the angle of the pics on the KW's, but if it's anything similar to how you have the MPHAS set you would have been okay just raising it up a bit.
09-26-2020, 04:25 PM | #17 |
Rep 5,211
I'm on MP-HAS with 9.5ET25 in front on RE-71R 265/35/19. Maybe you can keep your drop and add thin wheel spacers. If you run 295 or 305 out back on 10.5ET35 it should still look right.
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
09-26-2020, 05:44 PM | #18 |
Rep 5,961
Adding a spacer makes the wheel offset more aggressive (pushes wheel out farther); e.g., 9.5et22 + 5 mm spacer = 9.5et17
erictrainer277.00 |
09-26-2020, 08:25 PM | #19 | |
Rep 5,211
09-27-2020, 02:07 AM | #20 |
Rep 108
Glad I saw this thread since I'm about to order MP HAS and have a similar tire set up. What would be the lowest you could run with 265/35 and 305/30 and have no rub?
09-27-2020, 10:21 AM | #21 | |
Rep 5,961
Camber doesn’t help you add clearance because the strut and tire relative clearance doesn’t change with camber - the strut, steering knuckle and hub, brakes, and wheel all rotate as an assembly. |
erictrainer277.00 |
09-27-2020, 01:37 PM | #22 |
Rep 5,211
I just went out to do measurements and see if things need any adjustments the day after install.
- Both front adjusters are at 8 threads. - Drivers front has 1/4in clearance to the inner tire. (room for 2 stacked paint sticks) - Passenger front has 1/8in clearance in same spot. (1 paint stick just fits, not snug but no room to spare) For looks I wish I could come down another half inch in the fronts but the adjusting collar would rub the tire. I guess I'll have to give it time and see how the springs settle.
erictrainer277.00 |
