10-26-2020, 06:03 PM | #1 |
Rep 289
So I was taking a look around, there are a lot of bolts on the top of the shock tower. What sort of adjustability is there on the stock unit, any ability to adjust camber?
Also, anybody know the part number for this little dumb fastener that holds the rubber mat down. I almost broke it taking it off because it was... well I'm stupid. |
10-26-2020, 06:56 PM | #3 |
Rep 289
10-26-2020, 06:58 PM | #4 |
Rep 1,164
This should explain it
10-26-2020, 07:11 PM | #5 | |
Rep 289
11-24-2020, 12:56 PM | #7 |
Trackwarn
98
Rep 53
This is your camber solution.
https://f80.bimmerpost.com/forums/sh....php?t=1777830 |
h_bakken148.50 |
12-12-2020, 05:57 PM | #8 |
Trackwarn
98
Rep 53
Camber Solution
I moved from the GC plates to Millway plates. Sturdier construction, larger bearing (same size as OE) and works with the factory/KW hardware.
https://www.millway.se/camber-plates-m4-gts-f82.html The good stuff. |
12-17-2020, 12:51 PM | #10 |
Rep 289
There is another option out there which was actually recommended by the shop that I contacted in Austin Texas. Shop has a very good reputation and they say that they think these are the best on the market.
https://vorshlag-store.com/products/...31575223631934 |
