11-02-2020, 06:37 AM | #1 |
Rep 1
Runflats swapped for all season tires
Just had 4 new all season 20s put in staggered array (Ft 275/40R20 106(V or >)
Rr 315/35R20 110(V or >) at F 36, R 41 psi) same size as the runflats. Week later low pressure sensor alert and all 4 low pressure (F now 30, R now 35) with one rear tire at 24psi. Wheels original no changes. What is the problem? |
11-02-2020, 12:29 PM | #3 | |
Rep 2,995
NYBulldog1312.00 pennsiveguy3552.00 |
11-02-2020, 12:42 PM | #4 |
Rep 2,528
Happened to me many times when I lived in Tahoe. 80 in August vs 20 in November will do the trick, put some cold winter air to the proper pressure, reset TPMS and drive your car around the block. Problem solved.
11-02-2020, 01:56 PM | #5 |
Rep 1,062
Drives: F15 xDrive50i M-sport
That's happened to me, both at the tire shop and in my shop at home. Fill the tires with 70-degree air when the tires and rims are at 70 degrees, and then drive out into sub-freezing weather and watch the pressures and temps dive in the iDrive Tire Pressure Monitoring screen. In extreme -25 cold I've even had tires pull away from the beads and go totally flat.
2017 F15 xDrive50i M Sport | Superformance GT40 Roush 511 IR FE
11-02-2020, 11:34 PM | #6 |
Rep 1,354
Drives: 2022 X5 m50i
Just happened to me when I swapped the P Zeros with Vredestein all seasons. Like mentioned above, pumping in cold air when tires are cold does the trick.
2022 BMW X5 m50i
2024 MB S63 on order '18 X5 50i / '16 BMW F10 550xi / '13 BMW F10 535i / '07 BMW E64 630i / '03 BMW E65 745i / '95 BMW E34 540i / '89 BMW E30 M3 |
11-03-2020, 08:16 AM | #7 | |
Rep 290
Drives: 2020 M4
Garage List 2020 BMW / F82 [0.00]
2016 BMW X5 35i [0.00] 2012 Porsche 991 C2S [0.00] 2013 Audi S8 [0.00] 2004 Ferrari Challe ... [0.00] |
I would keep an eye on the one that dropped to 24 as that's a pretty big delta. |
