11-29-2020, 11:51 AM | #1 |
Rep 649
Unofficial Eventuri vs Karbonius Plenum/Intake Comparison
Well here it is: an unofficial visual/install/sound impression of the Eventuri vs Karbonius plenum/intakes from someone who has installed both in the same car.
The setups for my comparisons were as follows: Eventuri: - CF Plenum - CF Elbow/Filter - Stock Airbox Lid Karbonius: - CF Plenum - CF Intake - CF Airbox Lid - Macht Schnell (MS) Filter Visual: Pieces from both companies feel very high quality. The Eventuri undoubtedly has a better “finish” because of its use of a thicker clear coat. The Eventuri stuff is completely smooth across the outer surface with no imperfections whereas in the Karbonius pieces you can tell the clear coat is thinner. Because of this, you can see some imperfections in the surfaces of the Karbonius pieces (think pinholes and CF texture). Weight: All of the carbon bits from Karbonius are lighter than the Eventuri counterparts. If I had to guess I’d say the majority of this is due to Eventuri’s thicker clear coat on everything. Here are the weights broken down by component. Stock: - Plenum = 11lbs 4oz - Elbow w/o Filter = 1lb 6oz - Airbox Lid = 1lb 12oz - MS Filter = 2lbs 2oz Total = 16lbs 8oz Eventuri: - CF Plenum = 7lbs 10oz - CF Elbow/Filter = 2lbs 4oz - Stock Airbox Lid = 1lb 12oz Total = 11lbs 10oz Karbonius: - CF Plenum = 6lbs 0z - CF Elbow = 10oz - CF Airbox Lid = 12oz - MS Filter = 2lbs 2oz Total = 9lbs 8oz Fitment: When I purchased the Eventuri I had an issue with the angle of the PCV inlet on the bottom of the plenum. I sent the plenum back to Eventuri for repair and when I got it back the fitment was OEM-like. The Eventuri intake is a little tricky in part due to the dust shield on the bottom of the filter and getting the angle just right, but overall a straightforward install with no issues. The Karbonius plenum installed easily the first time with the lower cowl off. The angle of the IAT sensor attachment isn’t the same angle as the OEM plenum, but I had just enough slack in the connector to get it attached. The elbow of the Karbonius is where things start to get a little tricky. I initially wanted to try the ITG filter, but there was no way it would fit with my 2009 airbox nub so I retained my MS drop-in filter. It takes a few tries to get everything fit up but I managed to get it all in place. Then the issues began. The Karbonius airbox lid just does not fit like OEM no matter how you try to get it into place. My issue was specifically with the front corner where the air duct for the grills connects to the lower/upper airbox. The hole for the screw at that corner on the Karbonius lid does not line up with the lower airbox hole and the OEM screw is too short. I was able to slip that small elbow over the top/bottom pieces, but the fitment still isn’t ideal for the OCD. And I still need to source a longer screw. Sound: I’ll start by saying that I was expecting the Karbonius to be significantly louder than the Eventuri due to the lighter weight, but that wasn’t actually the case. The best way I can compare the two is that the Karbonius is more raw, throaty, guttural V8 race car whereas the Eventuri is more refined and exotic. I think it would be similar to how most people compare the Corsa vs Eisenmann Race mufflers. The tone differences don’t come across in video extremely well, but trust me it’s there. I think the Eventuri actually owes a lot of it’s exoticness to the elbow/filter design. The Eventuri feels as though it gets increasingly louder all the way to redline. The Karbonius growls from any RPM and is more prevalent at lower RPMs than the Eventuri is. But by comparison, the Karbonius almost seems to fall a little flat towards redline where the Eventuri is just shrieking. Both are unique and the sound really comes down to your overall preference. At the moment I still haven’t made up my mind as to which to keep. Not a bad problem to have, right? Pictures: Videos:
Le Mans Blue '09 BMW M3 Sedan - Current Polar Silver '04 Porsche GT3 - Gone Persian Blue '08 Lotus Exige S240 - Gone Space Gray/Imola '08 BMW M Coupe - Gone |
24
akkando5872.50 TimberWolf_306331.00 slcook541863.00 roastbeef11593.00 DanMpower3264.00 cvstar9M3286.00 aaa335252.50 ganz151.50 Not Sure223.00 Icecreamfoo134.00 UBERV8528.00 wyatth3553.00 m3less130.00 Bemo1122.00 InnerBlueSkies1092.50 SoCalRPM885.50 chief208.00 jamabdi242.50 icanturn27.00 ashutoshkotha38.50 M3-EffECtS3.00 IanMan384.00 a5m623.50 PACarGuy686.50 |
11-29-2020, 12:03 PM | #3 |
Rep 6,638
Nice thank you. If I get the eventuri intake I'll probably get the lid too, because..... 2020
11-29-2020, 03:56 PM | #6 |
Rep 5,932
The plenum + intake sound is influenced more by the filter than the elbow design. Using a MS filter with the Karbonius setup absolutely alters its sound. A better comparison would be using the complete Karbonius setup (which you weren’t able to) or the same filter on both setups. Including the weight of the (heavier?) MS filter in the total weight of the Karbonius setup also isn’t a true weight comparison.
11-29-2020, 04:12 PM | #7 |
Rep 979
Get them on dyno and keep the one that make hp....
2011 E92 M3 | JEREZ BLACK | EXTENDED BAMBOO NOVILLO | EXECUTIVE PKG | M-DRIVE | EDC | M-DCT
MODS | KW S/O | HRE P40SC | Akra Evo |ESS Akra Tune | ESS DCT tune | BMC drop in | StopTech Trophies | TMS Pulley | LUX V3 | BE Bearings and BE ARP rod bolts |
SilverSlug684.00 |
11-29-2020, 06:00 PM | #9 |
Rep 2,167
Thanks for the review!
To my ears, at least according to the sound clips the Karbonius sounds a bit better and more exotic actually. Too bad you aren't in SoCal or else I would help you with the comparison by adding in the CarboProject Plenum Export Version or what I refer to it as the "Banshee version". This thing freaking SCREAMS and drowns out even my Eisenmann Race + X-PIPE/HFC combo. |
Space Fox1042.00 Epoustouflant1164.00 |
11-29-2020, 06:36 PM | #10 | |||
Rep 649
8-10whp at best is pretty minor. This is more about the sound for me. Quote:
m34m697.00 |
11-29-2020, 08:10 PM | #11 |
Rep 272
It would be interesting if you can line up another Karbonius car with the non-"M V8" plenum design.
From one of the prior conversations I had with the builder, there are actually sound differences between the original plenum design that has just the BMW roundel and the later-added design that carries the M V8 logo.
~ S65 + Harrop Love ~
11-29-2020, 11:45 PM | #12 |
Rep 5,023
Thanks for going through the effort kcdedric ! This is great.
I'm digging that race-car Karbonius on the microphone. DanMpower Would be great to hear yours too! Maybe ask the OP what he used for a mic and where he placed it? Again, really appreciate these kinds of comparisons! |
m34m697.00 |
11-30-2020, 09:54 AM | #14 | ||
Rep 649
At least the heavier weight of the Eventuri plenum is mostly at the bottom. That's how it felt holding one in each hand anyways. I really was surprised how much lighter the Karbonius plenum was though. 1lb 10oz is not insignificant for a piece of that size, and to still be slightly larger is pretty remarkable.
11-30-2020, 01:17 PM | #15 |
Rep 510
Drives: 2007 E85 Z4 / 2013 E93 M3
I feel like this topic has been beat to death ha.
IMO, $2.5K+ for some sound (which is negligible if you have a louder exhaust setup) and only 6-10HP is just....that's just insane to me. That's nearly half way to a new out of the box SC kit, I just can't get behind stuff like this. Sure it looks cool, but it's more aesthetics and I'm more of a practical usability type of guy. To each their own I suppose, good luck! -Duke |
11-30-2020, 01:52 PM | #16 | |
Rep 1,881
i love the N/A aspect of the s65, and have always admired the induction noises of past M cars utilizing CF manifolds. For people like me, these CF plenum were a no brainer. |
11-30-2020, 02:25 PM | #17 | |
Rep 1,183
m34m697.00 |
11-30-2020, 05:09 PM | #19 | |
Rep 649
I think my next experiment will be to remove the bottom section of the cowl entirely since I'm already running the BMS cowl filters and my car doesn't see rain. I really want the Karbonius to be a little louder at high RPMs and then I think it's my perfect setup.
m34m697.00 |
11-30-2020, 06:59 PM | #21 | |
Rep 6,638
The induction noise from the plenum drowns out my Corsa muffler at full throttle. If it's not weird people spend money on an exhaust for sound, I don't see why spending on the intake system for sound is weird. Also it's not hard to come across a car with a loud exhaust, but 8 throttle bodies make the induction sound really unique on this car. I think it plays to this car's strengths to amp up the induction noise. Yea you could take the money spent on making the car sound great and put it toward performance, but you could also just buy a car that's faster than 2008 platform that was never cheap power to begin with. I mean you could have just bought a 335i and throw on some bigger turbos and a tune and come out ahead on performance and price. |
11-30-2020, 07:06 PM | #22 |
Rep 649
Update: took off the bottom section of the cowl and went for another test drive with the Karbonius. Verdict: I don't think the intake noise could possibly get any better. I mean, my god.
I'll let the video do the talking:
