12-01-2020, 10:21 PM | #1 |
Hey, where have you been all my life?
684
Rep 1,400
How often to replace injectors?
Wondering how often you guys replace your injectors?
I'm at 92k miles and about to do the rod bearings, and wondering what other preventative maintenance I should tackle at this point. Also, do you guys use any fuel additives to clean injectors? |
12-02-2020, 01:15 AM | #2 |
09 M3 e93 VF650, e30 e85, Remus, Federal’s 595rs
205
Rep 329
You can send them out to fuel injector clinic, I’ve never heard of somebody replacing injectors just because.
09 M3 E93 - VF650, AFD e30 e85, Remus Race, Federal’s 595 rs-pro’s.
SilverSlug684.00 |
12-02-2020, 04:13 AM | #3 |
BimmerPost Supporting Vendor
3392
Rep 7,544
No need to replace. Send them to RC to have them cleaned and flow tested. Injectors fail much more regularly and are replaced on direct injection platforms, rare to have a failure in port injected cars.
We have seen injectors down to 65% of original injection amount - many overlook this as a potential maintenance item. Good that you're thinking about it
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |----- ----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133---- |
SilverSlug684.00 Space Fox1042.00 |
12-02-2020, 04:45 AM | #4 | |
684
Rep 1,400
I checked out RC Engineering's website, they are in SoCal... so not too far away, and will return the injectors within 24hrs, which is awesome. Do you know what type of injectors the S65 runs? Top feed, hose feed or side feed? |
12-02-2020, 03:37 PM | #5 | |
Rep 2,145
Drives: 2011 E92 M3
Make sure you change the 2 o-rings when you service the injectors. There are no adjustemts or servicable parts. The injector service will run a bunch of concentrated cleaning agents through the injector to remove the swarf. They will also test to see if they hold a proper seal (which is not always accurate). That said, the cost to ship and test an injector is not far off the cost of just buying new ones. For $300 you can get 8 new injectors and all of the o-rings and clips from FCP. Shipping, testing and o-rings is likely going to run you at least $250 (160 for cleaning plus tax, $40 for fast shipping total, $50 for o-rings and no new clips). Hell, the lower o-ring is $5 each (perhaps the shop that services the injectors can throw in o-rings for a better price). You can clean them yourself with a few cheap accessories too. Check out this video:
2011 E92 M3 - 6MT, ZCP, ZF LSD, ESS G1, Some other goodies... |
12-02-2020, 05:12 PM | #6 |
684
Rep 1,400
This is awesome. Thanks for posting this!
Indeed cleaning myself sounds like something I would rather do. So I understand that the shop would flow test them as well, but they will not adjust them to flow better? |
12-02-2020, 05:43 PM | #7 | |
Rep 2,145
Drives: 2011 E92 M3
Cheers,
SilverSlug684.00 |
12-03-2020, 12:11 PM | #9 |
mTekMods
2169
Rep 2,922
injectors are cheap enough from fcp to just replace them with new bosch units
2011 Frozen Black/Fox Red E90 M3 650+WHP
G-Power Supercharged First DCT to Manual Conversion Worldwide KW CS, BBS RI-A, BW Headers, Snow 2.5 |
12-03-2020, 09:36 PM | #10 |
Rep 4,445
I considered getting my injectors serviced but found a new bosch set with clips on eBay from seller partscontainer for less than $280. Didn’t seem worth the effort to pull the injectors and have downtime.
12-04-2020, 12:56 AM | #12 |
Rep 860
If you've been down to the TA's before or themostat then it's a DIY. plenum off, remove wiring from injector, slide back spring clip.. (don't drop the spring clip). unbolt fuel rail. lift rail from engine with injectors. Remove sand/dirt from around the injectors before removal as best you can. drain pressure off fuel rail. Disconnect line. capture fuel runoff. cap line. flip rail around remove injector clip, remove injector. oil new o-rings. insert injector, injector clip, reassemble. Some have said you can do it without disconnecting the line but I don't see how unless you ran the fuel out of the system first by pulling fuel pump fuse. I don't have the document handy so If I missed something please correct me guys. Also I'll second the suggestion above - Why pay to pull old injectors, ship them, service them, when an entire brand new set with clips can be had right now for under 300 bucks? There was even a deal over the blackfriday weekend for them at FCP.
SilverSlug684.00 tigermack479.00 |
12-04-2020, 01:21 AM | #13 | |
684
Rep 1,400
Although I'm going to clean them myself and save $300 until I really need to replace them. |
12-04-2020, 01:47 AM | #14 |
Rep 2,747
Something to consider when cleaning injectors is it doesn't always address a passing issue.. solenoids stick for different reasons. Wear and tear, bad seals and physical hang ups.. cleaning is good for performance but wear is wear... as others have said if they're cheap enough new is new. I've had an injector flood a cylinder on a motorcycle before after 22k miles on a Honda CBR. Also consider duty cycles, if anyone is gonna stick a battery on one to hold it open, research the duty cycle to make sure it won't overheat it. I know some solenoids are designed to burn out when energized for too long like a an ice maker in a household refer, modern valves will burn after two minutes.
9ers
12-04-2020, 02:15 AM | #15 | |
684
Rep 1,400
I'm at 92k miles right now... Wondering if 100k is a good milestone for new injectors. |
SAMM3Y3086.50 |
12-04-2020, 02:22 AM | #16 | ||
Rep 2,747
9ers
12-04-2020, 10:10 AM | #17 |
Rep 237
On a related note. I've heard of some engine blocks destroyed silently. Internet theories say either a bad fuel pump, bad fuel filter, or most likely stuck injectors. There could be no truth to this as it's internet stories. Or could be bad tunes at work.
Would the car throw a check engine or have noticeable problem in engine feel if this issue was to arise? My mileage is lower but I do plan to do these someday. Don't want to be wasteful replacing them at 60k miles. |
12-04-2020, 11:30 PM | #18 |
Rep 4,445
Set of eight injectors for sale at rmeuropean for $200. Great price, grab em if you need em.
SilverSlug684.00 |
12-04-2020, 11:47 PM | #19 |
684
Rep 1,400
12-05-2020, 01:10 AM | #20 |
Rep 860
Bosch injectors will have a hologram security code on the box which you can run through their website to verify. Assuming someone hasn't faked that too. I suppose anything is possible.
SilverSlug684.00 |
12-05-2020, 10:59 AM | #21 | |
Rep 3,015
BMW Service and Parts are a business itself in which the dealerships / BMW NA can dictate the price on certain parts due to frequency of order/replacement and premium. They also can control the market when parts for certain models become scarce. I can tell you some of the prices for parts from the dealership are more expensive today, than they are 5 years ago. A good example of this are the coilpacks and ICV unit. Might not be for everything but for certain particular parts you see. Over the years production of some parts have also declined so I'm sure whatever is left the prices also fluctuate.
INSTAGRAM: GORDON.M3
North American Mr12Volt Carplay/Android Auto Distributor DINAN | EVOSPORT | VAC | ARP | RD SPORT | NEEZ | EIBACH | CSF | IND | BILSTEIN | KLASSEN | BREMBO | ENDLESS | BBS | BPM SPORT | PROJECT MU | EVENTURI |
SilverSlug684.00 |
12-05-2020, 10:18 PM | #22 |
Rep 4,445
Check the holograms. I’ve used rm a number of times and they sell legit items. Here are some pics regarding the hologram and authenticity check.
SilverSlug684.00 |
