12-12-2020, 01:46 PM | #1 |
Hey, where have you been all my life?
684
Rep 1,400
Anyone running magnetic drain plugs?
Anyone running Gold Plug brand of magnetic plugs for oil, trans or diff?
https://www.amazon.com/dp/B0838227CN...UTF8&psc=1 |
12-12-2020, 03:51 PM | #3 |
Rep 10,686
I run magnetic plugs. The front pan won’t fit a plug with much of a flange. I use one from a power sport application and I still had to grind it down a little. I never find and pieces of metal, but Sometimes find some fluff. It’s an aluminum motor. My iron block S52 has more fluff on the magnet.
SilverSlug684.00 |
12-12-2020, 08:21 PM | #4 | |
684
Rep 1,400
Is two magnetic plugs for the trans, diff oil complete overkill? Unnecessary? |
12-12-2020, 09:28 PM | #5 |
Rep 10,686
It’s a tiny bit of fuzz but it is magnetic. Trans and diff is even more recommended because there is no filter,
SilverSlug684.00 |
12-12-2020, 09:34 PM | #6 |
Rep 2,145
Drives: 2011 E92 M3
I do. Barely see any fluff on them. Bit of a waste on an aluminum engine. Go figure...
2011 E92 M3 - 6MT, ZCP, ZF LSD, ESS G1, Some other goodies... |
SilverSlug684.00 |
12-13-2020, 12:55 AM | #7 |
Rep 4,185
I run one for rear diff and one for engine oil sump. Still new, haven't removed it to check yet.
SilverSlug684.00 |
12-13-2020, 07:07 AM | #8 |
Rep 794
I use to run one, but stopped due to it snapping. I was lucky to still grab some threads and get it out. Did not feel like pulling the oil pan again.
SilverSlug684.00 |
12-13-2020, 11:58 AM | #9 |
684
Rep 1,400
12-13-2020, 03:41 PM | #10 |
Rep 105
I would like to know as well. I heard some old-timer say not to use a magnetic drain plug because it pulls the essential minerals within the oil away from the engine. Let me know how it goes.
12-13-2020, 06:33 PM | #11 |
Rep 4,185
LOL old timers. If you have iron in your oil, you're using the wrong oil.
