12-20-2020, 07:09 PM | #1 |
Rep 165
F15 N55 35i Mileage check
I just changed my oil and was curious who is currently leading the miles on the F15.
I currently have ~90,000 The F15 feels better than newer cars I have driven(Honda, Chevy) this is really a good keeper and feels like it's going to hit 200,000 miles without no major problems. |
12-20-2020, 08:42 PM | #2 |
Rep 334
Have you changed your water pump yet?
I am at 110,000KM (70k miles) I plan to do my coils at 120,000 as well as change the spark plugs again (60k KM interval) I'll be checking my belt tensioner and belt this summer aswell. After that its water pump that would be my major concern. Transfer case and F/R diff were done at 100K. Oil changes every 10K KM. I plan to keep it for another 5-7 years or atleast to 200k KM. Checks all the boxes for what I need it for. |
12-21-2020, 08:15 AM | #3 | |
Rep 165
What I did change on this f15 was the oil filter housing Oil filter cover gasket Oil pan gasket (Lower) Valve cover gasket New battery went from 90ah to 92ah What's next on the list is the both lower control brushing (bushing and ball joints) Haven't done that myself because I heard I need a special tool with pressure to take it out and put it back in. |
12-21-2020, 12:16 PM | #4 |
Rep 74
im at 136,000 km ... did coolant flush, oil changes ... will do an alignment soon ... no check engine or anything like that ... 2015 F15 ... i also did the brakes ... no issues car cranks no problem
12-21-2020, 01:06 PM | #5 |
Rep 101
I'm at ~111000 km (~69000 miles)
recently have had coolant flush, spark plugs, wheel alignment (brand new summer tires), oil change (last week), replaced cabin air filter, replaced engine air filter, front and rear brakes Lots of work put in the car this year, since I reached the 100k km, everything running smoothly 2015 F15 35i
Current:
2015 F15 X5 35i MSport - BSM/Black - RC RS - BMS CP Past: 2002 E53 X5 3.0i Sports Pkg - Titanium Silver/Black |
Surgx572.50 |
12-28-2020, 07:03 AM | #11 |
Rep 82
2014 35i with 105k miles here.
Nothing major except for the rear air suspension at 70k I'm up to speed with recommended maintenance. It's not my daily driver anymore so I would expect the miles won't go up as high as the first few years. No engine or transmission issues. |
12-28-2020, 07:21 PM | #12 | |
Rep 1,264
Surgx572.50 |
12-09-2021, 11:44 AM | #13 | |
Insta~ f10_sapphire
158
Rep 412
12-09-2021, 08:16 PM | #14 | ||
Rep 82
12-10-2021, 12:00 PM | #16 |
Rep 1,497
108K miles currently. Purchased it w/ 52K miles 4 years ago. Has been solid. About to do the front & rear diff and transfer case fluids. Other than that oil changes at every 6K miles. Refreshed the suspension w/ coilovers and front control arms this past year. Catless downpipe and full exhaust w/ BM3 stage 2 tune for the last 8-10K miles. Super fun to drive and as long as reliability is there I don't see me getting rid of her. Possibly a used G05 X5 40i in the future when (if) prices come down.
12-30-2021, 08:10 PM | #18 |
Rep 6
Just bought a 2014 x5 35i fully loaded with 118,000 miles.. Drives like a brand new vehicle and everything is so smooth! Hoping to drive it for a few years. Getting ready to do a BM3 tune, charge pipe, and maybe catless downpipe after that.
M302_imola844.50 |
01-01-2022, 10:13 PM | #19 |
Rep 58
Drives: 2014 X5 xDrive 35i
2014 35i with 144,000 miles. Bought at 92k. Nothing crazy other than a water pump at about 120k and control arms about 10k ago. Almost forgot a valve cover gasket around 100k that I replaced myself.
01-01-2022, 10:59 PM | #20 |
Rep 1,703
Drives: 2014 428i and 2018 X5
You're on borrowed time. You should do new spark plugs and coils, new differential and transfer case fluid and new transmission fluid / pan.
___________________ 2014 F32 428i M-Sport 2018 F15 M-Sport |
01-02-2022, 02:44 PM | #21 |
Rep 1,497
Did you replace all the front control arms on both sides? Just curious as I've replaced my passenger side ones, as I was getting a horrible squeak. I'm at 109K miles now. BTW, not far from you in Ooltewah, TN.
01-02-2022, 03:22 PM | #22 | |
Rep 58
M302_imola844.50 |
