12-24-2020, 02:38 PM | #1 |
Rep 136
Can I fit 275's in the rear?
Curious if anyone has a setup with offsets and rim sizes for a tire this size. I'd like to run this size to maximize grip and reduce wheelspin. Also thinking 255's in the front. Is this all possible? What size rim and offset should I use for this, if I can even fit these. Most I see is 255 and 265.
12-24-2020, 05:56 PM | #2 |
Working towards usefulness
161
Rep 239
09 128i Slicktop - Ohlins MI01S1, KMac Plates, M3 RSFB, M3 RSB, Hotchkis FSB/endlinks, 1M brace, Wavetrac, Coolerworx, JKVK headers, RPM Motorsport Tune, Yokohama A052 255/40/17s
Gangplank1544.50 Expert@ApexWheels3593.00 |
12-25-2020, 08:08 PM | #3 | |
Rep 136
12-26-2020, 10:06 AM | #4 |
Rep 6,196
A stickier 255 will give more grip than a less aggressive 275. The contact patch will be the exact same size if you are running a 225, 245 or 275, if used at the same pressure.
I do wish Michelin made a 275/30/18 MPS4S though. |
12-26-2020, 02:42 PM | #5 |
Rep 3,649
Just agreeing with this fact in case anyone finds it hard to believe. The contact patch will change shape, but generally speaking be the same overall size in square inches. (Wider tire stretches it out, of course, but because the overall size stays the same that patch gets slightly shorter front - rear. Wider tires would be beneficial for sideways motions i.e. hard cornering, skinnier tires are better for gripping during acceleration & braking, i.e. winter).
MightyMouseTech4337.50 |
12-26-2020, 03:06 PM | #6 |
Rep 136
Sorry, ya lost me there. Could you explain why the contact patch is the same with all of those sizes? I will be putting it on a 9.5" rim. You say if they are ran at the same pressure, I ask what pressure should those sizes be ran at?
12-26-2020, 06:12 PM | #7 |
Rep 3,649
psi = pounds per square inch
Let's say a tire is carrying an 800 pound load, and running at 40 psi...800 / 40 = 20 So you have a 20 square inch contact patch Make the tire wider, the patch stays the same, and so it gets a little smaller in the front / rear direction Size to run at = start w/ manufacturer's recommendations and go up or down from there depending on what you want to do and how you want to change how things handle - no 1 size fits all "should" run at |
12-26-2020, 06:52 PM | #8 | |
Rep 6,196
tracer bullet2542.00 |
12-26-2020, 07:49 PM | #9 | |
Rep 125
Coming from the Porsche world, I'm a little tired of overpriced Michelins Pilots. Used to devour the rears in 10-12k kilometres due to trackdays and too much rear camber. Moved to Kumho PS92 and my pocketbook is much happier. Probably lost a little time on the track but then I'm not racing my street car. That's what my 135i will be build for if I don't trade the DCT for a stick. |
12-26-2020, 08:09 PM | #10 | ||
Rep 6,196
12-30-2020, 02:00 PM | #11 |
YNWA
1069
Rep 820
PS4S is life
/// 2004 Silvergrey M3 · Coupe · 6MT · Slicktop · zero options
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54 |
01-03-2021, 02:46 AM | #12 | ||
Rep 1,017
Either Road & Track or Car and Driver did a really good article about 5 years ago on a BRZ riding on different size tires. There is definitely a sweet spot when it comes to track times as well as acceleration and braking and the widest tire is not always the best.
Official BMWP Whore - BMWP suspension kit w/ M3 arms, BMWP big brake kit, BMWP intake w/Mishimoto tube, BMWP exhaust, BMWP carbon strut brace, BMWP short shifter, and BMWP carbon spoiler. OZ Leggera HLT w/ 245 square setup.
01-03-2021, 01:02 PM | #13 |
Rep 3,649
Oh for sure, there are 100 other variables that affect things. There's always more to it.
It's a good theory to know though, to provide a basic idea of how things work. Lots of people think a wider tire automatically means more contact area, and don't understand that it's mostly just changing the shape. |
MightyMouseTech4337.50 tsk941526.00 |
01-04-2021, 04:41 PM | #14 |
1Addict
3243
Rep 7,910
Best thing to do is buy a good tire such as the MPS4S or RE71R. And make sure it doesn't rub anywhere. Rest is gravy tbh.
01-04-2021, 05:38 PM | #15 |
Rep 96
However, all else being equal, the 'optimal' pressure will typically be lower on the 275 than the 245, and lower on the 245 than the 225. Thus when set up properly, the wider tire would have a larger contact patch, and ultimately more grip than the same compound, construction, and diameter of narrower tire.
"Orville Wright did not have a pilot's license." -Gordon MacKenzie
01-04-2021, 06:12 PM | #16 | |
Rep 6,196
01-14-2021, 06:21 PM | #17 |
Rep 2,040
Drives: 2008 135 blk, blk, step
Garage List 1994 Porsche 968 Cab [0.00]
2017 AMG GTS [0.00] 1994 Porsche 968 Coupe [0.00] 1977 Mercedes 450SE ... [0.00] 2008 135 [8.00] |
Michelin PSS now PS4S is my favorite tire ever, use them on my Porsche also. I don't track my cars so I'm talking for daily driving.
Injen, RR OCC, MadDad Whisper, donut spare, 19x8.5et43fr 19x9.5et45r Volk LE37's, rear fenders rolled/pulled, PSS4S 225/35fr 255/30r, KW V1's, AR coated catless dps, Cross strutbar, CF grills and license plate holder, iCarbon diffuser, ETS black anodized FMIC, M3 control arms, Quaife, ER chargepipe, ForgeDV's, Topspeed Custom Tune, V3sims, Braille, Andrey_GTA rear hub mod, Ebay Mstyle front bumper and performance style side skirts.
01-20-2021, 07:01 PM | #18 | |
1Addict
3243
Rep 7,910
01-21-2021, 10:04 AM | #19 |
Rep 96
That's the legal CYA response, and is an entirely reasonable initial recommendation. It's also going to be more than adequate for the vast majority of non-competition consumers. The true optimal performance pressure will depend on a combination of many factors though, consisting of the entirety of your car setup, venue, and weather, and going well beyond what the supplier could account for... Which is why I referenced 'all else being equal'. The only way to truly find the optimal pressure for your particular car and setup, is through objective testing. Change anything in your setup (weight, spring rates, sway bars, alignment, wheel size, tire size, tire compound, tire construction, etc.), venue, or weather, and that optimal pressure might also change.
01-22-2021, 11:48 AM | #20 | ||
Rep 6,196
ShocknAwe3243.00 |
01-27-2021, 07:16 PM | #21 |
Rep 6,818
We tend to stick with stock pressures as a blanket recommendation to keep folks safe on the street. If you are tracking the car and really trying to optimize pressures you can bring the car in after a session and use a pyrometer to optimize pressures based on where the tires are warmer or cooler across the contact patch. The cold tire pressure will generally be lower than the street recommendation but they will come up to their working temp when on track. Ideal pressures will vary from day to day and even session to session depending on a host of factors like ambient temp, track surface temp and the tire compound/construction.
Generally speaking though once you've gotten to the point of optimizing your tire performance this finely you aren't even running street tires at all so it's rarely relevant for our street customers. If you are running the wheels and tires as a dual-duty setup and are tracking occasionally, you can check your pressures after the first session when the tires are still hot and air down a bit to get back to a more reasonable pressure range as pressures will likely increase on track. Remember to air the tires back up once the track day has ended though. Hope this helps! -Tom
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
