12-30-2020, 02:03 PM | #1 |
Rep 6
2017 650xi GC Tire Size
I have the above referenced model and needed to replace the stock tires as they were summer tires and I live in NY. Opted for Pilot Sport A/S 3+ from tirerack, however the rears have been backordered for a month and no date in site for delivery. The OEM tires are 275/30/20 in the rear and that is the size that are backordered. They have a set of 275/35/20 in stock, however said the 35 vs. 30 might not fit or could cause rubbing on the wheel well. Any advice? I have the new A/S on the front but am still running the summer tires on the rear and don't want to go too much further in to winter on them. Thanks
12-30-2020, 04:27 PM | #2 |
Rep 742
Because you have an "X" drive, the circumference of the tires are critical and you have to stick with the original sizes or you will prematurely wear out your transfer gear box even if they do fit.
12-30-2020, 09:50 PM | #3 | |
Rep 285
2015 Bmw 650i xDrive Gran Coupe
M Sports Edition Carbon Wing Carbon Front Splitters Carbon Rear Diffuser Carbon Grilles Powder Coated 373m Triple Bronze CPG intakes Arm catless downpipes Arm charge pipes Custom Snow Performance methanol injection Custom exhaust, straight pipes to quad tips Bootmod3 Stage 2 3.5 Tmaps xHP Stage 3 |
