01-02-2021, 07:25 PM | #1 |
Rep 87
2012 M3 Competition - DE Track Ready - No longer for sale
NO LONGER FOR SALE. Decided to keep for the 2021 DE season. 2012 BMW M3 Competition – $35,000. 70k Miles, Rod Bearings replaced. Car is not a show car, but a reliable track ready car. Fun, easy to drive, reliable DE car ready for the season. Best contact nejem@yahoo.com Car is meticulously maintained and has top of the line upgrades. Motion control Suspension, Stoptech ST40 BBK, Upgraded Differential, Carbon Fiber drive Shaft and Dinan exhaust. It is as close as getting to be a track car minus the interior being stripped and caged. Will make an excellent and reliable DE car and a daily driven street car. Over $35k in upgrades alone. - Oil changed every track event. Brake flushed every 3 track events - Rod bearings replaced at 50,000 miles with WPC treated bearings - New battery installed at 50,000 miles - DCT fluid changed/serviced at 50,000 miles and 60k miles - Wheel bearings replaced at 50,000 miles. - All service up to 56k done at Century BMW in Huntsville, AL...so records available - All service after done at local German specialty shop - All Rotors replaced 1000 miles ago Engine – - Bimmerworld extra large/non-spill power steering fluid reservoir installed - CSF upgraded radiator installed. - CSF upgraded oil cooler installed - DinanFree Flow Exhaust installed. - Primary cat delete pipe - Bimmerworld Oil Diverter valve - Matt Schnell Airbox - Alex Alpine GTS tune - Car is coded for Euro MDM if you want to drive with nannies on. Transmission – DCT - Turner Motorsports 3-Clutch Variable Ramp limited slip installed...3.45 rear gearing. - Euro GTS DCT tune - M Factory Carbon Fiber Drive Shaft Suspension – - Motion Control Suspenstion two way adjustable - MCS 2WNR (2 way rebound & compression adjustable non¬remote); rebuilt/revalved a few thousand miles ago. - Vorshlag Camber Plates - Hyperco Springs Front 2.25" x 6" 600 lbs /Rear 2.25" x 9" 900 lbs - Hyperco Helper Springs - Hyperco Helper Spring Guides - HPA Rear ride height adjusters - Powerflex Street/Track (Black) Rear Shock Mounts - Bimmerworld Adjustable End Links - ECS rear control arm - MSI wheel studs are installed. - Powerflex Race bushings installed in most front and rear postions. - Bimmerworld Precision Front Lower Control Arm Bearing installed. - BBK Brakes – - Stop ST40 BBK in all four corners Wheels – Square setup, Buyer will have a choice of which rims to keep with the car. - 19x9.5 BMW wheels in all four corners. (square set-up) - 18X9.5 APEX wheels for track use. - 18x10 APEX wheels for track use Driver and passenger Schroth 4 point harness anchor points are installed, and harness is included if you want it . Last edited by intercool; 02-13-2021 at 09:24 AM.. Reason: No longer for sale |
01-06-2021, 04:05 PM | #4 |
Rep 87
Here is a video of the exhaust. I have other videos with the car on track. Keep in mind that I AM SLOW!!! Don't judge my lap times vs the car's capabilities. Also, the car is compliant on Sunday quiet hours at road atlanta and I have NOT been black flagged for being too loud.
