01-05-2021, 05:24 PM | #1 |
Rep 327
Methanol Injection question
I'm just asking this because all my lifts are tied up at my shop and this was easier.
I want to add Methanol Injection to my F85. We do a lot of Meth kits on late model Corvettes and always use the windshield washer reservoir with the pump mounted right below it. This way it's a straight gravity feed right to the pump. Does anyone know if there is enough room to do this in the F85? I really don't want to run long lines to a reservoir in the back. Either way, I'll make my own TFE stainless braided lines. I don't like those plastic compression fitting lines. I also firmly believe in running 100% M1 Methanol rather than a water mix. I'd rather not have that inside the car.
2021 Individual Grigio Telesto Gray Pearl Metallic X5M C, BC Forged, Dinan tuned, Dinan suspension, MAD Downpipes, Dinan Exhaust. More to come.
Owner, Designer, Tuner- A&A Corvette Superchargers WWW.AACORVETTE.COM |
01-05-2021, 06:46 PM | #2 |
IG: @88jae88
1624
Rep 1,742
IMO I think you should make a kit providing this type of setup as an alternate because I haven't seen any other kind of kit for this platform other than the one that runs to the rear of the vehicle.
IM POOR..
01-05-2021, 10:13 PM | #4 |
Rep 327
If there is room under the reservoir, there is no reason not to do it this way.
The pump is gravity fed and you don't have the big delay caused by a long line to the back of the vehicle. I'll get it up on the rack later this week and see if it's viable. I just bought Brembo calipers and mounting brackets for the rear, so I need to get it up in the air to install them anyway.
01-05-2021, 10:39 PM | #5 |
Rep 90
Unfortunately there isn't enough room under the reservoir as it's tucked in the front right fender extremely tight. I had the windshield washer pump grommet start leaking and that required me to remove the front right fender to repair it. It is extremely tight in the space.
2016 X5M DGM BM3 Stage 1 91
RK Autowerks Intake & RW Carbon parts |
01-05-2021, 11:18 PM | #6 | |
Rep 327
Pulling the fender would not scare me away at all. If I had to notch and weld the frame to fit a pump in there, I wouldn't hesitate to do it. There also might be room to the inboard side of the tank, right up against the firewall. I'm reasonably talented in overcoming issues like this but I'm really fortunate in that I have a couple of excellent welders and fabricators that work for me. If it's possible, I believe we can do it. I'm not even sure it's worth the effort, but I really enjoy doing one-off modifications that nobody else had tried.
NikNala75.00 |
01-06-2021, 12:49 PM | #7 |
Rep 1,564
What about the drivers side fender well? The E70 drivers side front fender well has a ton of open space, perfect for a small meth tank. You can access it just by pulling the wheel well cover. Quite a few things changed on the F85 but also alot didn't so might check it out and see if that empty space is still there.
01-07-2021, 03:11 PM | #9 |
Rep 327
I like the idea of using the windshield washer reservoir. The low fluid light will come on when it gets low.
If that's not viable, I'll find somewhere to mount a tank. We could weld one up in stainless and make it any shape we want with mounting brackets.
