proTUNING Freaks
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > BMW M3 (F80) and BMW M4 (F82) General Forum
      01-09-2021, 10:10 PM   #1
Gertsee
Gertsee's Avatar
REP
89
Drives: BMW 435i
KIES Crank Seal Guard
Thoughts on this?
I'm guessing these OFHG leaks are more common on the N54/N55 platforms but since the S55 and N55 share so many of the same components I wonder if this would be worth the investment?
      01-09-2021, 11:07 PM   #2
9M71
REP
1,196
Drives: M3
This video has made me paranoid. Engine blocks sucking in the belt then imploding? Add this to my list of nightmares.
      01-09-2021, 11:09 PM   #3
N1rve
Racecar Driver
N1rve's Avatar
REP
2,430
Drives: BMW M4
2019 BMW M4  [9.70]
First I’ve ever heard of this.
      01-09-2021, 11:09 PM   #4
fiveohwblow
fiveohwblow's Avatar
REP
1,398
Drives: F15, E46 & M3, F82
Happened to me on my e92. Created a year long nightmare I’d LOVE to forget. The issue is real, just not sure how real it is on s55...
      01-10-2021, 12:08 AM   #5
icegrill
icegrill's Avatar
2,078
REP
1,809
Drives: 2015 M3
Better not be a damn issue on the s55 already been down this road with the N54.
      01-10-2021, 12:32 AM   #6
jpy1980
jpy1980's Avatar
REP
1,971
Drives: 2015 BMW M3 -Smurfy Blue Vinyl
Sounds like a good idea: https://f80.bimmerpost.com/forums/sh....php?t=1623258
      01-10-2021, 01:12 AM   #7
MisterF80M3
MisterF80M3's Avatar
1,067
REP
1,170
Drives: 2018 M3
Wish I saw this before I put my CBC on..
2018 BMW F80 ///M3
570WHP/578TQ
      01-10-2021, 01:28 AM   #8
fiveohwblow
REP
1,398
Makes two of us
From5toM142.50
      01-10-2021, 07:10 PM   #9
maddmatth
Australia
566
REP
940
Drives: E92 M3 | Prev:E92 335i, F82 M4
This was a known issue on the N54 and N55... I would have thought BMW have corrected this for the newer engines.
Are there any known cases of this actually happening? I haven't seen any. The case linked above didn't result in any pieces of the belt getting inside the engine.
Sounds like a case of trying to make money by fear mongering...
      01-10-2021, 07:12 PM   #10
jmciver
///M SubDriver
jmciver's Avatar
REP
2,796
Drives: 2017 M3, 2020 X7 40i
2024 BMW i4 M50  [8.00]
2017 BMW M3  [10.00]
2020 BMW X7  [0.00]
2019 BMW X3  [0.00]
This is a nice solution, and not that difficult to install. But it still does not replace proper preventative maintenance on these cars or any car. Barring an unpredictable catastrophic failure of the belt (which appear to be rare), inspecting/replacing your drive belts and also routine inspection for oil leaks (like from the valve cover) will keep your engine running fine. Even the other thread posted above states the importance of routine preventative maintenance - which many people are not that good about, especially once the BMW factory maintenance plan expires.
My M3 just went past the 50k mile point. A "far" visual inspection of my belts (i.e. not taking anything apart to get a closer look) indicates they are good and also no oil leaks coming from the engine. However, as part of my 50k mile maintenance, I plan to replace both belts, the belt tensioner and the two idler pulleys - that is ~$300 in parts and a few hours of my time. As a comparison, the Kies solution is $199 and the work/time to install it is essentially identical.
So in IMHO does this solution help protect you from a potential problem on the S55? Sure. Is it a critical must have? Not if you do your preventative inspections and maintenance (or pay someone to do it if you can't/won't do it yourself).
i4 ///M50 - 2024 G26 Dravit Grey Metallic
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic
      01-10-2021, 09:29 PM   #11
Imperial328i
Imperial328i's Avatar
REP
558
Drives: 2015 MGM 328i, 2017 LBB M2
My M3 just went past the 50k mile point. A “far” visual inspection of my belts (i.e. not taking anything apart to get a closer look) indicates they are good and also no oil leaks coming from the engine. However, as part of my 50k mile maintenance, I plan to replace both belts, the belt tensioner and the two idler pulleys - that is ~$270 parts and a few hours of my time. As a comparison, the Kies solution is $199 and the work/time to install it is essentially identical.
So in IMHO does this solution help protect you from a potential problem on the S55? Sure. Is it a critical must have? Not if you do your preventative inspections and maintenance (or pay someone to do it if you can’t/won’t do it yourself).
I saw this piece and I wanted it. I saw it cost $200 and I hesitated. Then I read your post and yeah, no way I'm buying that thing. I can't help but tinker with my car. Hell today I spent three hours conditioning my seats and then taking apart the engine bay to clean stuff. Definitely inspected the OFH while I was there. I'm an aircraft mechanic and I like to treat my car like an airplane. It should be taken apart semi-frequently to be inspected and cleaned. I was able to remove a bunch of leaves from my cowl drains, use Sonax Gummi-Pfleger on some rubber boots and seals, and get a good general look around. I think I'll spot a problem long before catastrophe.
2017 F80 ZCP - Mineral Grey Metallic
jmciver1928.00
PhatLyfe982.50
2011ninja3463.50
SCS55304.00
      01-11-2021, 02:16 PM   #12
Gertsee
Gertsee's Avatar
REP
89
Drives: BMW 435i
At what mileage would it be ideal to change belts?
      01-11-2021, 02:18 PM   #13
tom @ eas
BimmerPost Supporting Vendor
tom @ eas's Avatar
REP
19,171
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
BMW says 90K, we change at 60K.
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
Gertsee54.00
arashir162.00
      01-11-2021, 08:50 PM   #14
jpy1980
jpy1980's Avatar
REP
1,971
Hey Tom!
I was just there today and asked Kevin about the belt job, but totally forgot to get the labor only quote!
I have these parts on me, is that the complete list of items needed for the belt job? See attached photo.
Also I added the obligatory “in front of EAS” cell phone photo!
Julian
tom @ eas8852.00
      01-11-2021, 09:08 PM   #15
2011ninja
2011ninja's Avatar
Jamaica
3,464
REP
2,670
Drives: 2022 G80 6MT
Hey Tom!
Also I added the obligatory "in front of EAS" cell phone photo!
Julian
Hey Tom!
Julian
That's a great PSA ⭐️⭐️⭐️⭐️⭐️
+1 for the factory 18's absolutely perfect ride balance
Sport/comfort
      01-11-2021, 09:13 PM   #16
RugbyBro
RugbyBro's Avatar
7,283
REP
3,671
Drives: M3
FWIW I saw that VTT sells a crank seal guard like this for $69 (niceee) - under the N54/N55 section
Current: E92, E46
Prior: F80, F82, F32
Shubacca129.00
      01-11-2021, 09:21 PM   #17
Jbonly21
Jbonly21's Avatar
REP
984
Drives: Bmw 15 F80, 2011 X5 35i, E46 M
Best thing to do is change your belt and tensioner earlier, it's such a pain trying to get the broken belt out of the crank seal, happen to my X5 with an N55 engine .
https://youtube.com/user/Jbonly21
      01-11-2021, 09:27 PM   #18
jpy1980
jpy1980's Avatar
REP
1,971
Sport/comfort
Werd!!!
I just “upgraded” in “ride comfort” by trading my Titan7 19 inch wheels for the 513m wheels. BEST DECISION EVER. ride is awesome on 40 profile tires!!
Car also looks more racecar-y. I shouldve never sold them in the first place!!
ntg442886.00
      01-12-2021, 12:53 PM   #19
tom @ eas
tom @ eas's Avatar
REP
19,171
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Hey Tom!
Julian
Nice! I'll work on the quote for you right now and follow up via PM.
      01-12-2021, 01:25 PM   #20
Twistm4
I Drag Race My Track Car
Twistm4's Avatar
203
REP
226
Drives: 2015 M4
Its more of a likely hood the OFHG gasket fails on the side that mates to the block, rather than the bottom like on the n54. If it fails you're way more likely to see oil in your coolant (happened to mine at 59k) rather than external leaks onto the belt.
Basically a non issue on s55. Scary as shit in the past though..
      01-13-2021, 11:29 AM   #21
mad1stgen
Master Wagon Builder
mad1stgen's Avatar
481
REP
911
Drives: 2015 F wagon S55/6MT
How do you figure this ?
S55 uses the same oil filter housing/cooler setup as all other N5x engines, and the same two gaskets as every single I6 BMW for the last 15 years.
Open your hood once a while and check for leaks. It's a BMW. Whether the seal guard is a good idea, well that's another story.
      01-13-2021, 12:02 PM   #22
Twistm4
Twistm4's Avatar
203
REP
226
Drives: 2015 M4
Because I am an all knowing genius.
Lol on a serious note I've never seen this happen on s55. But have seen the gasket fail, which sucks because you have to take the manifold off to get to the last bolt on this design. Theres still a bit of oil spots in the coolant res. But a year later its been fine. Just drained it. Didn't even pressure flush.
f80post
