01-11-2021, 11:16 PM | #1 |
6586
Rep 5,305
MCS 1WNR or 2WR?
Hey guys,
I figure this forum will have the most experience with this damper set. Let me know what you think. Currently I'm running JRZ RS2 Sport and it's about time I get them serviced. But in the meantime, I've been thinking of getting a set of MCS dampers. My F80 has become a daily driver for the most part these days but will hopefully be seeing some autocross and track days this coming year. But the main use will still be overwhelmingly daily driving. The 1WNR is attractive to me because of the low cost of entry. But the thought of going from a 2-way to a 1-way kinda makes me hesitant. Speaking with Bimmerworld reps, they steered me to the 1WNR based on what my needs were and the fact that it has more shock travel compared to the the MCS 2WNR. Does the MCS 1WNR have more shock travel compared to the JRZ RS2? If yes, I would consider this an upgrade despite losing the compression control. For reference, I rotate between 400lb/in and 500lb/in + 225lb/in tender for the front. 700lb/in and 800lb/in for the rear. I tend to run the compression on the rears pretty soft compared to the front for daily driving and bring up the compression for autocross events. Will the lack of compression control on the 1WNR put the compression in the middle or be more biased to the front to give more compliance on the street? The 2WR is obviously a massive step up but also a massive step up in price. Having separate controls for compression and rebound does put me more in my comfort zone though. Is the extra control and canisters worth the bump in price? Thanks. |
01-12-2021, 12:06 AM | #2 |
Rep 3,792
I was in this same position a few months ago. At that time, I kept leaning 1 way because it was still a major upgrade over the stock suspension but as nice as it is to save a decent wad of cash - in retrospect, not having compression adjustment on a good suspension would suck for me.
01-12-2021, 12:06 PM | #3 | |
6586
Rep 5,305
01-12-2021, 03:10 PM | #4 |
Rep 886
Something you may want to consider is the added adjustability of nitrogen psi on the 2WR dampers. There's psi ranges for street and psi ranges for track. I've been messing around with mine, and it's super noticeable...when I am on my "street" nitrogen psi, and have my C|R settings in the low ranges, the ride is amazingly compliant and plush, all while having excellent road composure from the MCS valving.
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs |
Unheardmyth21.00 |
01-12-2021, 03:27 PM | #5 | |
6586
Rep 5,305
01-12-2021, 03:55 PM | #6 | |
Rep 108
I was in the same boat as you before getting my RS2s serviced. After years of car modding, the best advice I have a hard time following myself is to just get what you want in the first place. If you're already thinking of a tradeoff going to from 2-way to 1-way, it'll just be a matter of time before you upgrade to the MCS 2-ways. |
01-12-2021, 05:24 PM | #7 |
///M Powered for Life
11517
Rep 10,345
For street use there is a decently sized upgrade in moving from the non remote options to the remote ones. Instantly noticeable right on the street
The 1WNR is a great option but I'd prefer the Remote. I currently have two cars on the MCS 3WR and if I get a G80 it will directly get the same dampers. But my use case, heavy tracking, is not everyone else's use case. For the spring rates you're running the 1WNR will handle those just fine. |
01-12-2021, 05:25 PM | #8 |
11517
Rep 10,345
You can either fill it up just once at a shop or you get your own nitrogen kit. I have mine so I can set them wherever I want, although I don't touch them and they don't lose pressure. I think it was 800 for the nitrogen rig setup
01-12-2021, 10:09 PM | #9 |
Rep 3,792
01-14-2021, 10:47 AM | #11 |
Rep 859
01-14-2021, 04:35 PM | #14 | |
Rep 886
Coilover or non-coilover rear btw? I'm a coilover rear...600F/500R springs on the car at the moment, 5in front spring (to fit big ole tires) and a 0 rate helper with the bimmerworld plastic/metal washers so nothing binds up. I also had custom brackets made to mount the front reservoirs parallel/adjacent to our cf strut bar. Street/Track Nitrogen PSI guide attached:
fanatic11018.50 |
01-14-2021, 05:17 PM | #15 | |
6586
Rep 5,305
Starting out, I'm going to stick with the inboard spring set up on the rear. However, I believe the kit will include the parts for a true coilover set up if I choose to go that route in the future. Spring rates will be 500F/700R because that's what I have now. But I've been wanting to go to a 800R. One more question... During installation, can you route the canisters to the engine bay and trunk without disconnecting them? Also, I'd love to see a picture of your canister strut mounting solution. |
sly1types431.50 |
01-14-2021, 06:11 PM | #16 | |
Rep 5,976
For the F8x, only the front dampers/struts come standard with a reservoir quick dry release connection. The quick release is an option on rear dampers. However, the reservoir on the rear dampers can be easily routed into the trunk by removing the two snap-in side vents in the trunk. You do have to remove the front reservoirs to be able to route them into the engine bay. Don’t forget to bleed off the reservoir pressure before disconnecting them. You can get a portable N2 tank setup for ~$600 and a reservoir pressure gauge for ~$100-150. I think it’s worth the investment and is definitely something you should have with you at the track. |
fanatic11018.50 |
01-14-2021, 06:37 PM | #17 | |
6586
Rep 5,305
Starting to think I should just stick to the 1-way Non Remotes now.... |
01-14-2021, 06:51 PM | #18 | ||
Rep 886
The front canister routing hole you will use on install is massive, and sits under the stock air boxes. U pull the fender liner back to "make" the hole. Assemble your coilovers and have your local preferred race shop pressurize everything before u do the install.
01-14-2021, 07:46 PM | #19 | |
6586
Rep 5,305
So just to be clear, the canister being bled and disconnected isn't a necessary step in the install; it's just to make routing it easier right? I know I posted in the track forum, but for my needs/wants at the moment, my car isn't going to see track time until later this year the earliest. Please pardon me if my questions are a bit neewb as this will be my first set up with remote reservoirs. |
01-14-2021, 07:57 PM | #20 | |
Rep 5,976
01-14-2021, 08:09 PM | #21 | |
6586
Rep 5,305
01-14-2021, 09:14 PM | #22 |
11517
Rep 10,345
I don't know where you are in the US but I'm sure there are people willing to help out filling your canisters
