01-14-2021, 07:14 PM | #1 |
Rep 958
New CA checks
I didn't want to clutter the CG thread so I figure I'd start a new one here. Found the document for new smog check addition to OBD functionality check. A few of you asked me for more info. If you're tuned and go in for a smog check, you'll get caught.
Due to the following: Calibration Verification Number (CVN): a number set by OEMs to verify the integrity of the vehicle software Calibration Identification (Cal-ID): an ID for the software installed on the Electronic Control Unit (ECU) https://www.bar.ca.gov/pdf/On_Board_...n_10.17.19.pdf
M4CS Frozen Blue
ARM DP's/Resonated Mid-pipe | SPL links | Hotchkis bars | JRZ RS2/camber plates | K&N | Koyorad HX | Powerflex purple | Rouge | Spiegler | Speed Eng. snorkel | Vargas CBC/hub | Wagner IC | xHP | Xpel stealth ppf Last edited by Wanted_M; 01-14-2021 at 07:26 PM.. |
01-14-2021, 07:23 PM | #3 |
Rep 958
As far as I know, If its you're original OEM map then probably yes.
M4CS Frozen Blue
ARM DP's/Resonated Mid-pipe | SPL links | Hotchkis bars | JRZ RS2/camber plates | K&N | Koyorad HX | Powerflex purple | Rouge | Spiegler | Speed Eng. snorkel | Vargas CBC/hub | Wagner IC | xHP | Xpel stealth ppf |
01-14-2021, 09:38 PM | #4 |
Rep 502
It's only a matter of time until cops will start asking us to plug into our OBDII instead of popping our hoods when we get pulled over...
If anyone figures out how to modify a tune to show the stock CVN and CAL ID I will gladly throw you my money! |
01-14-2021, 10:40 PM | #5 |
Rep 1,978
Well thanks goodness the m is fast out of the box...but I mainly tuned for the gts roar and deleting the cold start..haha bah...
01-15-2021, 08:16 PM | #6 |
Master of one
431
Rep 486
imagine all those lease returns that were tuned. I'm sure the dealership can find a way to reset it so it can be resold
papasmurf_m3454.50 |
01-18-2021, 07:08 PM | #7 | |
Rep 290
Re: showing stock CVN and CalID, it’s only software, so someone should be certainly be able to figure it out!
'17 i8 Protonic Red Edition; '17 “30 Jahre” M3
'90 Z1 Red w/red/black leather, GC coilovers, Alpina Dynamic DS-02 '91 850i Mauritius Blue/Black, BBS RS-GT '85 M635CSi Alpine w/buffalo; '03 M3 Conv, Imola ‘85 323i Baur; ‘02 X5 4.6is Estoril; ‘95 Racing Dynamics K30.4 |
HyeM3464.50 |
01-18-2021, 07:54 PM | #9 |
Rep 958
Don't be too happy, CO is also looking into activating this as they follow CA smog rules.
M4CS Frozen Blue
01-20-2021, 12:02 PM | #11 |
Rep 151
In the Evo world, you would have to have the dealer flash your ECU back to stock. Then you would take your car to the Ref station and the Ref would pass you once you told them and showed them the dealer flashed your car back to stock. I'm not sure if the CVN or Cal ID numbers changed back to "stock" / number the smog bar is looking for, which I thought was the CVN. Maybe the Ref noted in the system the "new" CVN / Cal ID number after going back to stock?
Stock Evos were also flagged to go to the Ref station due to a recall on the ECU. Some owners did not get the recall done, so the smog board flagged them to visit the Ref station and the only way to pass was to get the recall done at the dealer (Paper work had to be shown as well).
Passively looking for a F80 M3 Competition & Executive w/ manual trans in all colors but black. Prefer 2018 and Carbon Cloth seats.
01-20-2021, 12:15 PM | #12 | ||
Rep 958
M4CS Frozen Blue
MisterF80M31061.00 |
01-20-2021, 01:31 PM | #13 | |
Rep 2,371
I'm in El Paso County, but really, every county other than Douglass, Adams, and a couple others that make up the greater Denver/Boulder area, is not going to have smog checks. Unfortunately, Denver and Boulder have turned the state blue (not even purple any more, straight blue), and there is always a chance this could effect things on a state level. All the Californians moving here, voting the same as they voted in CA, and expecting a different result...
2015 Black Sapphire Metallic 6MT M4
01-26-2021, 09:53 AM | #14 |
Rep 186
Drives: BMW X3MC LCI
01-27-2021, 08:20 PM | #15 |
Rep 6,638
01-27-2021, 09:07 PM | #17 | |
Rep 186
When are these checks supposed to start? |
01-27-2021, 09:13 PM | #18 |
Rep 502
They started in summer 2020. But you won't fail yet if you have a tune installed. What's going to happen is your car will be flagged and on your next smog check you'll have to go to the state ref. Within the next couple years though they're going to make it to where you'll actually fail the smog test if you have a tune installed
Wanted_M772.50 |
01-27-2021, 10:07 PM | #19 | |
Rep 958
Makes me wonder at what point the state will start checking flash counter.
M4CS Frozen Blue
01-27-2021, 11:03 PM | #20 |
Rep 502
Yeah for the most part. However I think they can also grab an oem map from another M3/4 and send it to you if you deleted your stock one. As long as it's an oem file for your model (base/comp/cs etc) and not one they tried to recreate it should be good
01-28-2021, 07:47 AM | #21 | |
Sad ///M noises
4197
Rep 1,798
Also how does this affect legal tuning which gets approved by the government and put into the vehicles papers, because the software wouldn’t be the original either? |
01-28-2021, 10:43 AM | #22 |
Rep 502
It shouldn't affect it. They'd most likely put the CAL ID and CVN from those tunes into their system so when your car comes in with that software on it you won't fail
