01-19-2021, 07:38 AM | #1 |
Rep 36
Carbn ceramic brake upgrade
Hey guys i have a 2015 M3. was thinking of doing the carbon ceramic brakes upgrade. online I've seen something about getting an upgraded brake booster ?? the bmw tech told me I don't need that. that the brakes will just mount right up. anybody has experience with the swap ? thanks
01-19-2021, 09:40 AM | #3 |
Rep 820
I am going through the upgrade and you do need the CCB specific brake booster. I just purchased one for ~450 from getbmwparts. There are also couple bolts and gaskets you will need as well. I'll pay the part numbers for you later.
01-19-2021, 09:59 AM | #4 | |
M Enthusiast
438
Rep 626
Drives: 2018 F80 M3 ZCP
2018 F80 M3 ZCP - CCB - MPE - BBS RI-D - Pure Turbos Stage 2+ - 3D Design Bumper - KW Clubsport 3 Way - Cary Jordan E85 Tuned
2021 F97 X3MC 2017 F30 340i (SOLD) 2015 F82 M4 (SOLD) |
01-19-2021, 01:42 PM | #5 |
Rep 820
If your spending this type of money do it right. Brake booster and associated part numbers are below.
34-33-7-850-999 Booster 34-33-6-857-618 Booster Gasket 07-12-9-906-196 Brake Master Cylinder Nut |
01-19-2021, 02:10 PM | #6 |
Rep 1,009
01-19-2021, 02:52 PM | #7 |
Rep 820
There are also dust shields that are specific to the CCBs, due to the tight clearance between the caliper and the wheel. Rocks can get stuck and permanently damage the wheel, so these can help to mitigate that issue. Knowing that bit of information I picked them up. The info is below:
Part Number Part Name Price 34-11-2-284-767 Splash Shield $48.99 34-11-2-284-768 Splash Shield $48.99 34-10-6-864-424 Carrier Bolt $5.61 I decided to get new caliper carrier bolts as well as they are cheap and I'm not skimping on brakes. They are kind of important. |
01-19-2021, 02:59 PM | #8 | |
Rep 820
Please don't go cheap on brake parts. BMW used a different booster for a reason. |
01-19-2021, 03:41 PM | #9 | |
Rep 2,369
Drives: G87 M2; E92M3 MT&DCT; M3 euro
Assuming frictionless incompressible fluid (typical synthetic oil) and constant net pressure, higher velocity at a control surface would equate to less local pressure which would translate to a softer pedal. Thus, if the oil used is the same but the pressure at the pedal is different, it is either the brake pistons/mating surface/both that are creating more resistance or the flow rate by the brake booster, or both. I just looked up the parts and dimensions for rotor diameters and brake pads are identical. This leads me to believe that the fluid velocity by CCBs brake booster could be slower than that of normal steel brakes, unless the resistance from the CCBs are far greater than that of steel brakes in which case would need a brake booster that results in faster velocity. (and still may result in firmer brake pedal)
Pass me if you can.
01-19-2021, 04:15 PM | #10 |
Rep 14,141
Drives: G82 M4C X-Drive
This is an expensive mod for what you get. Is brake dust really that much of a problem?
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
01-19-2021, 04:52 PM | #11 | |
Rep 117
to the OP - not sure if I missed this, but why do you want to upgrade? Looks? Performance? low dust?
Danny
Bay Area, CA |
01-19-2021, 04:57 PM | #12 |
Rep 896
Do CCBs not provide significantly better braking power, or is it mostly about brake dust?
I picked up my F80 with 3k miles on the clock. It had been preowned for 3 years, so was clearly a garage queen. Everything on the car was essentially new and the stock non-CCB brakes have been one of the most underwhelming features of the car. I would have expected MUCH better stopping power.
Previously:
2010 E92 335 (6MT) 2011 E92 M3 ZCP (6MT) |
01-19-2021, 06:02 PM | #13 | |
Rep 117
you'll notice many of the F8X reviews were done on CCB.
Danny
Bay Area, CA |
01-19-2021, 07:29 PM | #14 |
Rep 820
On my past car, a F-Type SVR the CCBs were amazing. Better pedal feel and initial bite then the same model car with steel brakes. Although Jag steel brakes leave something to be desired. They even felt better then the 6 piston Alcon brakes I had on the car before. I'm hoping that BMW CCBs are close, I loved those brakes.
One thing I forgot as well is the ISTA coding needed after the retrofit. Not sure exactly what's in the coding but I'll see if I can find more information. |
01-19-2021, 08:35 PM | #15 |
Rep 3,651
f80s kind of lack in braking power. probably because the engine is so powerful. and partly due to the small front tire patch compared to other FR performance cars.
You won't really feel much of a difference with ccb for street use. But on track they'll shine more because of the reduced weight and fade resistance. if you're just worried about dust... swap in ceramic pads.
2018 Porsche GT3 6MT 2021 M2C DCT Previous: Ferrari 458 | R35 GTR | F80 M3 | E46 M3 | E36 M3 | Scion FRS |
01-20-2021, 12:10 AM | #16 | |
Rep 83
Except that all I hear is the brakes may not last a weekend or two before they burn up and have to be replaced. That's probably worst case, as I feel I've heard some people talk about using them for numerous track sessions. Either way, they're still a REALLY expensive mod that only provides a little better brake fade, but on the flip side there seem to be too many reports of track use not ideal because of reduced life expectancy. |
01-20-2021, 03:09 AM | #17 | |
Schmollbraten
12515
Rep 1,985
BMW CCB's are lacking at wet streets, are very sensitive to small stones and I see meanwhile lots of disc with small crates from outbroken chips. Before I had bought my car, I'd driven few M4 with CCB in different conditions, no one came even close to my RS5 brakes. So for me an upgrade into a 12000,- Euro range is much too much for too less effort and for sure not for the prevention of the dust.
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
01-20-2021, 03:19 AM | #18 | |
Rep 8,189
Track brake pads go a long way on these, though. Just get you some Ferodo DS pads, they're even cheaper than OE street pads and not that noisy. BMW also sells M Performance pads which, I think, are re-branded Pagids. I'm all about detailing, but I don't find brake dust to be an issue. I normally wash the car every two weeks anyway.
01-20-2021, 05:49 AM | #19 |
Rep 257
An often missed point about CCBs is weight reduction. Other than the benefits to braking itself (which are debatable at best in a street car), the real benefit of CCBs is reduction of a SIGNIFICANT amount of rotating unsprung weight.
See pics when I took off my CCBs and replaced with steel rotors. Incidentally, with CCBs, my F80CS weighed in at 3600 lbs - same weight as an M2 competition. That's wet weight including three quarter tank of gas. |
01-20-2021, 06:08 AM | #20 | |
Rep 820
01-20-2021, 06:27 AM | #21 |
Rep 820
Seems as though I had it backwards, although I did read that this another thread. I will take what BMW says and admit my mistake.
Here is what the CCB guide(attached) for the M5/M6 says about the booster: "5.3. Brake Booster The brake booster is specifically designed for the increased coefficient of friction of the M Carbon ceramic brake. This is why it has its own part number. Without this adaptation, the behavior of the M Carbon ceramic brakes would be rated as disproportionately aggressive." So this leaves the question about the soft pedal. There is another thread from a week ago that discuss the need to run the ISTA DSC bleed procedure https://f80.bimmerpost.com/forums/sh....php?t=1785786 |
01-20-2021, 08:01 AM | #22 |
Schmollbraten
12515
Rep 1,985
With 450HP you would complain about 20kgs more?
Well, Im out
