01-28-2021, 09:02 PM | #1 |
Rep 942
Topping off with another oil brand
When I change my oil I use BMW twin power turbo 10W 60 oil change kit from FCP.
You guys know how expensive that damn stuff is and my car burns 3L of it between every 5k oil change. Would it be okay for top off the 3L between changes with much less expensive liqui moly 10w 60? I promise I searched!
2013 e92 M3
2011 X5 35d 2018 F80 M3 ZCP |
01-28-2021, 09:10 PM | #2 |
Rep 237
Yes absolutely. People tend to overthink this, mixing oil is perfectly fine. It's also done to achieve a certain viscosity.
I used to be paranoid about oil being 100% the same because of stupid online myths. In time I realized how it makes no sense. As long as you aren't mixing conventional with synthetic. I wouldn't experiment with that. |
DL335D582.50 |
01-29-2021, 05:05 PM | #4 |
Rep 10,686
I agree with not overthinking this sort of thing. The additive packages among oil brands in the same weight are not identical but I would not worry. Unless you are tracking the car, I would not even worry about mixing weights or running a lighter weight oil like 0W40, 5W40 or 5W50. Change the rod bearings, change the oil regularly, let the engine warm up before exceeding 3000 rpm, and enjoy the car.
01-29-2021, 07:14 PM | #6 |
Rep 942
I know. The local performance shop ran a dye test and a compression test. They found nothing. Such a pita always adding oil. The shop told me that for the S65 bmw's threshold is 1.2L approx every 600 miles. How crazy is that.
2013 e92 M3
01-29-2021, 07:30 PM | #7 |
Rep 10,686
Right, it’s well within spec. My car uses a fair amount as well. I don’t really keep track but think it’s probably in the range of 2-3L per 5000 miles. I have run mostly thinner 0W40 and am often cruising at 4000 rpm. I think if I ran thicker oil and drove slower consumption would be a little less.
DL335D582.50 |
01-30-2021, 06:45 AM | #10 |
Rep 942
You are one of the lucky ones. I'm not mechanically inclined. Besides paying 4K for a 6yr 50k exclusionary policy, I haven't paid anything additional except for crazy expensive oil changes. The warranty company has already paid out over 6k in just 15 months.
2013 e92 M3
01-30-2021, 11:32 AM | #11 |
Rep 7,141
3L/5k miles, jeez! Can't be right, don't car what BMW are trying to cover their A with.
Still, your engine seem to run fine. Mine doesnt drink a drop between changes, where are these crazy differences between engines come from?? |
