BMW X5 and X6 Forum 2014-Current
      02-09-2021, 07:28 AM   #1
svenker
Drives: BMW x5 F15 40e
Battery disconnect & reconnect tips
Hello everyone,
This coming WE, I will install my Android/Car-Play module
However, it seems that I should disconnect the battery before installing it all.
I have the 40e, a few questions:
Should I disconnect the left or right battery please ? (looking from the back)
When I reconnect, do I need any coding ? I have the ETHE cable and the bimmercode application which is great.
Thanks for your support !
      02-09-2021, 09:03 AM   #2
quandary
Drives: X5
If you disconnect one of them (the right one when looking from the trunk to the front in my 35d), it will reset your steering and create a DSC warning when starting to drive. You will need to recalibrate the steering. I didn't find this option in Bimmercode and had to go to ISTA-D on a laptop which you can find online. (If you are under warranty, you can still drive it to the dealer and have them recalibrate it for you; just tell them that your batteries drained dead because you had a light on.)
There is no specific coding for the batteries unless you are also going to change them at the same time. The coding applies to the left one and only resets the counters (i.e. date of battery swap and number of hours under-voltage) to allow the computer to make decisions around the life and charging cycles. You can do this through the Bimmercode app. (When I asked them about the 2nd one, they didn't know about it but i realized that it was not being managed by the computer since it doesn't power important items.)
      02-09-2021, 10:52 AM   #3
Qsilver7
Qsilver7's Avatar
Drives: F06 650ix GC / F15 X5 50i
If you have 2 batteries...when you disconnect the main battery, the aux battery is still powered so be careful. If you do not want anything powered, then remove the negative terminal from BOTH batteries.
Ditto the post above, you won't need to "code" the batteries just because they were disconnected. But you may need to reinitialize some things around the vehicle...one of those things is the sunroof. You'll probably need to do a reset (push up & hold the sunroof button until it runs through its cycle...this info is in the owners manual). You may also need to reset the clock (depending on how long the batteries are disconnected).
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral.
      02-09-2021, 05:37 PM   #4
j.maldo
j.maldo's Avatar
Drives: BMW X5 40e iperformance
Hi, just in case, remember to first disconnect the high voltage battery, then disconnect the other 12 volt batteries before starting the job.
      02-10-2021, 06:56 AM   #5
svenker
Thanks for all your messages !
Seem very complex compared to my old cars
Let me recap:
- Disconnect the high voltage (right panel in the back) but confused exactly where this one is...
- Disconnect Aux battery (left from the back),
- Disconnect Main battery (right)
Do the job required - Android...
- Reconnect Main
- Reconnect Aux
- Reconnect High Voltage
- Reset Sunroof, clock
- Reset steering with cable and ISTA-D (which I never did so far).
Are these the correct steps ?
      02-10-2021, 09:31 AM   #6
j.maldo
j.maldo's Avatar
Yes, seems correct. The high voltage battery circuit interruptor is located in the middle of the right side compartment. You will see the green switch as in the picture. Very important that this is the first battery you disconnect and the last one to be reconnected. Also, for safety, when you disengage the green switch, there is a small hole for a lock of (zip tie) to prevent the switch from accidentally engaging an energizing the system while you're working.
      02-10-2021, 10:08 AM   #7
turboawd
Drives: 2015 X5 35i
Most important thing is make sure ignition is off and car is asleep before disconnecting cables.
      02-10-2021, 03:11 PM   #8
svenker
Thanks. Car is asleep? Do I need to sing a sleeping song? :-)
This high voltage is because I have a hybrid 40e car ?
      02-10-2021, 03:33 PM   #9
j.maldo
j.maldo's Avatar
Yes, just some extra steps.
      11-08-2021, 04:03 AM   #10
Andy_Kay
Drives: X5
I'm going to be disconnecting my 12v batt in my 40e soon, so wondering about this 'car is asleep' comment. What steps do I do to make it fall asleep?
      11-08-2021, 09:29 AM   #11
RED_Y_
Drives: 2014 X5 3.5d
Just wait 15 minutes.
      11-22-2021, 09:45 AM   #12
Andy_Kay
Drives: X5
Let me recap:
- Reconnect Main
- Reconnect Aux
Just about to change my big (main) battery as I think it's got an issue not holding charge.
Do I need to disconnect the smaller 'Aux' battery first? I notice these steps were to change some audio thingy, but I'm just doing a swap of Main (bigger) battery.
So would my steps be
- Disconnect (bigger) Main battery (mines on the left looking in from the boot/trunk)
- do the change over
- connect Main battery terminals (is it negative first, then positive?)
- reconnect high voltage green plug
- Do the ISTA 'new battery procedure'
I'm actually changing from 90a to 95a battery G14 019 Varta AGM. Do I need to do anything different in ISTA to tell it it's now 95 instead of 90a?
      03-23-2023, 03:49 PM   #13
jholicjosh
Drives: x5 40e
Hi Andy_Kay, I have the similar issue. Did you end up calibrating the steering wheel while replacing the batteries? I need to replace 12v battery and the AUX (AGM) battery. I'm fine with all the procedures except steering wheel part.
      03-23-2023, 04:03 PM   #14
corduroy
Drives: '16 X5 xDrive40e (F15)
Not OP, but I've changed both batteries and never had to calibrate the steering wheel.
      03-23-2023, 04:21 PM   #15
imr3n
Drives: BMW X5 2014
for some reason, when I changed my car battery, my f15 threw a chassis stabilization malfunction error when I started to drive it and turned the steering wheel. After looking online, I found some steps to recalibrate it, and the error message went away.
I was surprised by the error, thought I screwed up or something...
xbimmers
