02-26-2021, 09:40 AM | #1 |
F86, G05, E91
455
Rep 778
F86 Oil Change
Here is my first oil change experience. Froze my @&$ off in my CT garage. Need a heater. Lol.
02-26-2021, 10:49 AM | #4 |
Rep 1,040
Drives: BMW X5M, M3 ZCP, MB E63 AMG
And what about the engine flush stuff, you put in prior to changing the oil?
02-26-2021, 10:58 AM | #5 |
F86, G05, E91
455
Rep 778
02-26-2021, 11:10 AM | #6 |
OEM CSL Whore
1255
Rep 1,476
Thanks for the video. I think I've driven 500 miles in the last year since wfh. I'll start changing my oil now as I'm officially out of maintenance warranty.
DgjoX6M2016455.00 musa424.00 |
02-26-2021, 02:02 PM | #7 | |
Rep 1,040
In my E63 AMG, I also drain the oil cooler, that yields about 1/2 quart by itself. For my next oil change on the X5M, I'm going to use Liqui Moly, and try their Ceratac Ceramic. |
02-26-2021, 07:45 PM | #8 |
Rep 340
Drives: Several
Garage List 2004 Ferrari 360 Sp ... [0.00]
2015 Ford F150 Lari ... [0.00] 2015 Porsche GT3 [0.00] 2017 BMW X5M [0.00] 2020 BMW X7 M50i [0.00] |
Great post, thank u!
I may get crucified for this but when the oil drain gets slow I will usually crank the engine and let it run for about 2-3 seconds and cut it off. It will usually yield another 1/2 quart. I figure that this amount of time is the same as waiting on the oil to start circulating any time u start the car. |
02-27-2021, 05:24 AM | #9 |
Rep 592
Drives: 2018 X5M , 14%E2%80%99640i ver
Great great video, if only I had my youth back ( & no arthritis) I would be crawling under cars.
DgjoX6M2016455.00 |
02-27-2021, 02:27 PM | #10 |
Rep 223
Drives: F86 X6M // E53 X5 4.8is
Very nice video and great work. Thanks for posting.
DgjoX6M2016455.00 |
03-01-2021, 09:55 AM | #11 |
Rep 7,584
EDIT: oops...I jumped the gun and wrote this before watching your video to the end...where you mention you discovered why you had the extra bits...which were for the early n63 engines.
Ditto...great video. But to answer a question you asked (approx 13:34 into your video) as to having some spare parts left over from the oil filter kit...that is due to early versions of the n63 engine have a drain in the oil filter cap. This extra drainage capability was phased out as the N63TU/TU2/etc was phased in across the F & G chassis models...but the oil drain cap is used on multiple models (the old style & new style). If you have one of the original caps with a drain and need a new one...then your new one will be "drain-less". You can see the drain plug and gasket (#3 & #4) in the F models (5/6/7/X5/X6) diagram below. And as noticed in your video...having a drain in the oil filter cap probably wasn't a bad idea...not sure why BMW stepped away from being able to drain the oil out of the filter...it would be a little less messy. But due to those early models having a drain...the oil kit has the extra bits in them.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 03-01-2021 at 10:18 AM.. |
03-01-2021, 10:24 AM | #12 |
Rep 352
Very informative video - nice job!
2016 BMW X5M F85 | 2019 - Present
2015 BMW X5 F15 5.0i m-sport | 2016-2019 2001 BMW X5 3.0i Sport | 2005 - 2008 |
DgjoX6M2016455.00 |
03-01-2021, 12:39 PM | #13 | |
F86, G05, E91
455
Rep 778
What DIDN'T make the final cut...kinda embarrassing...was me mucking around the hot oil for signs of a damn o-ring. Lol. I drained it slowly with a mesh and all. Of course found nothing. |
