03-02-2021, 02:23 PM | #2 |
Rep 545
Drives: 2015 M5 CP - 2022 M5 CS
That’s a nice price, especially considering the bushing is already pressed/included. If it’s solid delrin, that’s for sure going to increase vibration in the cab. I wouldn’t necessarily consider that “better,” unless you have a race car that isn’t a daily driver.
I’m running the RK billet diff mount with the stock bushing and it’s a great setup. Zero issues with vibration or driveability. The stock bushing is not what fails with high HP applications - it’s the cast mount itself. Both options obviously address that. |
SCD-1983581.00 |
03-02-2021, 02:51 PM | #3 | |
Rep 43
Also like that GAW comes with a bushing and I don't have to pay up swap it out from my stock unit. So I can swap back to stock once I go to sell the vehicle fairly easily. But again looking or reviews before I pull the trigger! Last edited by Bmyguy88; 03-02-2021 at 03:37 PM.. |
03-02-2021, 03:07 PM | #4 |
Rep 545
Cool man, pick one up and let us know how you like it!
10-22-2021, 12:26 AM | #6 |
Rep 545
The bushing is not sold as a separate unit - it’s only sold as part of the diff mount.
Plenty of used mounts on ebay that you can rob the bushing from. When I reinstalled mine - I filled the stock mount with liquid poly. Nice because it’s still totally quiet but quite a bit more durable than the stock bushing. |
TinCanSailor641.00 |
11-07-2021, 04:43 PM | #7 | |
Rep 31
11-08-2021, 04:21 PM | #8 | |
Fueled by Recycled Dinosaurs!
641
Rep 1,179
Drives: F06 M6
any details on product and technique would be greatly appreciated.
2015 F06 M6 Silverstone Metallic II, Individual Full Leather, B&O, Night Vis, CCB, RKAutowerks (CP Rods/Pistons, DI Cams, CF Intakes, Coated DP's & Billet Diff Brace), InfinityAuto Turbo Inlets, Mishi Oil Cooler, JB4, XHP S3, BM S3
11-08-2021, 09:38 PM | #9 |
Rep 545
Picked up a black two part injectable polyurethane by 3M, as well as a applicator gun (sold separately).
I also grabbed a used OE diff mount from ebay for $50. After installing the OE bushing in the RK diff mount, I made a mold from a couple Gatorade caps. I drilled a central hole in the caps, put nut/bolt thru mount with caps on each side. Made a small hole in the top cap to inject the poly, then filled the mount. Left the poly to dry for 48hrs - then removed the caps and had a super clean filled bushing. It could be done much simpler - but I wanted an OEM look/mold, so that’s the point of the Gatorade caps. One could easily just tape up the edges of the bushing and fill away. You’d likely get an imperfect looking result but functionally it would be the same. |
11-08-2021, 10:12 PM | #10 |
641
Rep 1,179
Drives: F06 M6
I genuinely appreciate the knowledge share sir. I might be the only person to see it but after years of shop work with my grandfather; I am a fit and finish guy thanks to his in fluence. I recently plastic welded some cracks in the splash shield on under the engine. I probably spent more money in man hours than the damn thing cost in dollars but the results were well worth it and learned a great deal about the different types of plastic in the process.
I've been searching ebay for a rear diff purely for the purpose of having a battle spare bushing. So now I'll have one ready to swap the day I do the brace.
Doctor_X1158.00 |
11-09-2021, 11:20 AM | #11 |
Rep 545
I appreciate thoughtful work just like you sir! Unfortunately when I look at my toys, I can only see the defects. When something is done 99.8% correctly, I only see the 0.2% that was done wrong. It’s a curse, but a blessing to the eyes when modding cars
11-09-2021, 10:09 PM | #12 | |
641
Rep 1,179
Drives: F06 M6
I liken it to chasing down the green flash at sunset. It is not that the 1000's of other sunsets are terrible
