03-09-2021, 12:24 AM | #1 |
Rep 7
2016 650i door wood trim removal help?
Hey folks, I need some advice removing some trim in my 6 series, I'm in the process of removing all my trim, I have already removed most of it but I am stuck on the door trim, I cannot find any information online about removing the trim, does anyone have some information that can help me remove the trim?
03-09-2021, 01:51 AM | #2 |
Rep 1,833
Drives: BMW iX Xdrive40 MSport
Its actually quite tricky. Once you remove the door card you have to remove the trim clips that hold it in place. The really tricky part is that there is a hidden clip on the near side to the door card. Word of caution, once you get it off you need to be very careful when installing it back in the door card. You can very easily damage the leather on the door card. I’ll try and find you the instructions.
Lawrence2K0.00 |
03-09-2021, 12:38 PM | #3 | |
Rep 7
03-09-2021, 01:33 PM | #4 |
Rep 1,833
Here you go...No.2 in the diagrams is the tricky little bugger. It sits behind the switch-block for the power windows and is a PITA to remove on the driver's door. There are plenty of plastic guide pins on these parts so take care when removing and installing them. The window switch for the passenger door just levers out (gently, take care to not damage the wood). Instructions for the driver door window switches also below
Current: iX Xdrive40 | MSport | 22" Bicolour | Amido Interior | Mineral White Metallic Last edited by hugo_nz; 03-09-2021 at 01:45 PM.. |
Lawrence2K0.00 |
03-09-2021, 06:29 PM | #5 | |
Rep 7
03-09-2021, 10:41 PM | #6 |
Rep 2,926
Yes, you have to remove the entire door panel. The pictures are showing where the screws are on the back of the door panel. It's not hard. The hardest part is holding it while you unclip all the wires.
03-15-2021, 03:32 PM | #8 | |
Rep 7
Passengers door panel removal help
Thanks for all the help |
03-15-2021, 05:33 PM | #9 | |
Rep 1,833
Current: iX Xdrive40 | MSport | 22" Bicolour | Amido Interior | Mineral White Metallic |
