03-24-2021, 08:04 AM | #1 |
Rep 80
Diagnosing: Thermostat vs. Coolant Temp Sensor
I bought a 2016 X5 35i with ~75k miles roughly a month ago. I had pre purchase inspection done at the dealer, the bmw master tech showed me the Control unit tree which was all green at the time, no issues.
Driving yesterday I noticed my engine temp remain at the lowest setting without increasing as I drove, no heat coming into the car and a loud noise from outside, which ended up being my fan running at full speed during my entire drive of about 15 minutes. FYI driving home the fan didn't turn on, however I did get a CEL, and the engine temp was very slow to raise and it never got to normal operating temp. Got home and ran my scans, I will start with the coolant temp sensor. Any feedback or thoughts if I should be aware of anything else. Could this potentially be a thermostat issue as well? Fault Code: Thermostat jammed open. OBD2 Codes: U1408: (can't find definitive for what this is) P0128: Coolant temp For some odd reason I am also getting something about the battery being old, which is odd. If I don't drive the car for a week I usually have it hooked up to an 'intelligent' trickle charger. |
03-24-2021, 10:41 AM | #2 |
Rep 2,529
Keep in mind that temperature on the dash is not the coolant, it is the oil. I would try to clear all errors in ISTA, drive around the block and see what comes back.
03-24-2021, 12:54 PM | #4 |
Rep 2,995
04-14-2021, 07:22 PM | #5 |
Rep 80
Quick update, I replaced the coolant temp sensor with an OEM BMW one ($50). Replaced it, cleared the codes and drove trouble free for the last 3 weeks (1,000km).
CEL came on again, same two codes: OBD2 Codes: U1408: (can't find definitive for what this is) P0128: Coolant temp Will delete again and report back. If it comes back I guess the thermostat will be next? FYI the engine oil temp gauge is functioning normal and I don't have the fan coming on excessively like it did originally. |
04-14-2021, 08:01 PM | #6 |
Rep 2,529
Check this thread out:
https://www.bimmerfest.com/threads/s...-help.1317145/ |
HJ478.00 |
04-15-2021, 05:22 AM | #7 | |
Rep 80
To keep documenting in this thread, the linked thread has a number of people with the same problem who replaced thermostats and the problem didn't go away. A poster did state this however which is promising: "For me they first replaced the MAP thermostat PN 11-53-8-635-689. That did nothing and the car still wasn't coming up to operating temp in time. The oil temp would hang at 70C on the bottom end of the gauge - even after a 30-40 min drive. I also kept getting intermittent check engine lights for P0128 and U1408 codes. I took it back to the dealer and they replaced the auto transmission oil cooler (heat exchanger) PN 17-21-7-600-553. There is second thermostat on this part that went bad. That solved the problem. My car now comes up to operating temp after a 10 min or so drive on the highway - even in very cold weather. I can't find it now, but if you search the internet you will see evidence that this is a somewhat common problem." Also I wonder if this is true (from another poster): "There***8217;s an extended warranty for thermostats stuck open 10 years 120,000 miles" |
05-06-2021, 01:54 PM | #10 |
Rep 1,547
Drives: '22 Tesla MY + '23 Tesla MY
Should have bought a diesel
| '22 Tesla Model Y P - My daily | '23 Tesla Model Y LR - Wife's daily | '17 F15 35D - missed daily |
05-07-2021, 12:20 PM | #12 |
Rep 1,547
Sorry, inside joke. I know the OP personally
08-03-2021, 09:14 AM | #13 |
Rep 8
Any update?
10-07-2021, 09:59 PM | #14 |
Check out my Youtube @n55david!
1306
Rep 3,554
Drives: 2017 m240i, 2015 X3 x35i
curious here too.. same issue
2017 m240i xDrive 10.67@132.32mph w/bm3
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
03-07-2023, 06:48 PM | #17 | |
Rep 1,497
03-09-2023, 10:56 AM | #19 |
Rep 1,497
That's exactly what I did. Crazy thing is I did an oil change right before the kit showed up and the CEL vanished. Radiator fan quit working overtime and oil temp start to rise to normal. Drove the car 100 or so miles and then just like I suspected it triggered another CEL. I'll get the t-stat and waterpump replaced next week.
03-09-2023, 07:08 PM | #20 | |
Rep 358
BMW knows how to make some over-complicated shit! This includes the entire cooling system. |
M302_imola844.50 |
03-09-2023, 08:23 PM | #21 |
Rep 1,038
M302_imola844.50 |
