03-24-2021, 11:13 PM | #1 |
Rep 39
N54 Running Lean / Massive Smoke/ Coolant In oil
Hello, Sorry for putting 3 series stuff in the one series side, but I'm really lost on this and could use some help if anyone has any ideas on what this might be.
My 08 335i N54, has an HUGE ISSUE! This is from my previous post, update is listed further bellow. Larger Silicon Inlets BMS Cone Intakes VRSF Inner Cooler Upgraded Turbos MHD Stage 2 Tune 50/50 E85/E91 DKM Stage 3 Plus w/ Single Mass Flywheel VRSF Cat less Downpipes Oil Catch Can Upgraded Low Pressure Fuel Pump VRSF Charge Pipe After my new clutch install I drove the car 600 miles all moderately, under 4000 rpms. After I broke on my clutch I drove the car HARD, some really good pulls. After some time I noticed there was MASSIVE grey/white smoke, also may I mention when I say massive smoke I couldn't even see out my rear windows. When I got back home I checked my oil level and it was good (if the oil sensor read it properly), next there was oil in my coolant. The car did feel to have a power loss but I was able to drive 50 mph to get home. I'm pulling codes 2C2C not present 2DED not present 2A2C not present 2C7F not present Update Main Issues, Massive white/grey smoke from tailpipes (when I save massive I mean a big deiseal roiling coal but white) Power loss, but able to go 50 mph Oil in coolant no coolant in oil( that I see) I did a leak down test and I have a leak from the oil filler cap. I don't believe this is normal, but I'm also worried this is the only issue I have if oil is in my coolant. ANY HELP WOULD BE VEREY MUCH APPERICATIED!! THANK YOU!!! |
03-25-2021, 10:48 AM | #2 |
Rep 1,017
I hope it's just the gasket that let go and not the head or block. Either way, you're rebuilding your engine. Sorry to be the bearer of bad news. Had you been noticing any detonation?
Official BMWP Whore - BMWP suspension kit w/ M3 arms, BMWP big brake kit, BMWP intake w/Mishimoto tube, BMWP exhaust, BMWP carbon strut brace, BMWP short shifter, and BMWP carbon spoiler. OZ Leggera HLT w/ 245 square setup.
03-25-2021, 11:22 AM | #4 |
Rep 1,017
How many miles did you drive after you first noticed the problem?
03-25-2021, 09:59 PM | #6 |
Rep 1,017
True, but a sudden burst of white vapor and limp mode sounds a lot scarier than a bad OFHG. I’d prefer to be wrong just because I don’t want to see anyone go through that, but methinks it’s pretty serious.
OP, how much coolant do you have left? Do you have a noticeable drop in coolant?
