EXXEL Distributions
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Suspension | Brakes | Chassis
      03-27-2021, 07:04 AM   #1
horsepower_and_hounds
EDC sensors, plugs and function
So let me throw this out there..... I am curious. When you have an OEM EDC suspension set up you have the damper control feed on top of the dampers then you have the accelerometers on the sides of the dampers. When you have an OEM Passive set up you have none of these.
OK........
When you do a EDC delete you plug in the deletes to the damper feed on top of the dampers but you leave the accelerometers installed?
Ok........
When you do the code out process you unplug the box in the trunk..... then remove the accelerometers from the dampers and stow all unused connectors from the 8 locations?
So at any point in all this does the suspension controls ever cross communicate with the DME to work with TC, throttle, etc?
I always thought that the system was interconnected somewhat but I never see any communication about this......
f80post
