03-30-2021, 10:45 PM | #1 |
Rep 85
On for track time attack battle soon against stock M2 CS . Both on Cup 2. 1M has few setup modifications
- KW v3 - front sway bar - camber plate - corner balanced - Front brembo BBK - Pagid RSL29 front and rear - front brake ducts Your thoughts ? Got any chance excluding driving skills 1M Dino grape Blue vs stock M2 CS |
03-30-2021, 11:05 PM | #2 |
Rep 2,819
Drives: e82 1M, f87 M2cs
If you haven't added oil cooling capacity, you may find limp mode before you get any heat in the Cup2's. Ask me how I know....
I ran Toyo T1R's on the 1M last year, and am pretty sure my M2CS would let me break all my lap records on its stock PSS's.
1M track toy mods: BMS chargepipe, BMS OCC, ADE FMIC, ADE motor mounts, MadDad/Lightweight Ti exhaust, ADE custom oil thermostat/cooler, custom MHD tune, F10 550i clutch, Ohlins R+T, Vorschlag camber plates, M3 'vert FSB with Turner endlinks, Stoptech Trophy BBK.
03-31-2021, 12:21 AM | #4 | |
Rep 2,819
I paid Andy Divers (ADE) about $1000 total for a massive oil cooler, larger lines, custom thermostat housing with 170 degree pill, custom air shroud and protective grill painted black. Now I can run his custom tune instead of resorting to MHD stage 1 for track.
03-31-2021, 09:21 AM | #6 |
Rep 2,819
Mods in sig
92 octane. 450wtq 3000-4500 rpm, 380hp 5900 rpm -2.7 camber front, -2.2 camber rear
03-31-2021, 10:42 AM | #8 |
Rep 2,819
Got it. :
03-31-2021, 11:46 AM | #9 | |
Rep 85
- Akropovic evolution system - Akropovic down pipe - TTE 500 turbos - Forge FMIC - ER charge pipe - NGK spar plugs - K & N sport filter - Dinan oil cooler Tuned by etuners on 93 octane |
03-31-2021, 10:27 PM | #11 |
Rep 85
05-09-2021, 09:17 PM | #12 |
Rep 478
All depends on skill. On a 64 second track where engine power doesn't really matter, same tyres (Cup2) - approx 0.6 quicker than myself with just camber plates. Everything else stock bar track pads/fluid.
On more traditional tracks where engine power is more influential, close to a second per 65seconds on the old E8x/E9x stuff. The F8x diff makes the car so much easier to put power down and maintain forward motion. Our OEM diffs are always costing several metres on exit as it is too slow to engage and imprecise which makes it harder to be on or close to the limit.
Bilstein CS | Rays ZE40 | Solid/spherical front / rear.
YouTube |
