04-14-2021, 01:06 AM | #1 |
Rep 22
22 inch tire help
Just bought a set of 22 inch rims for my 2016 f16 22x10 front 22x11 back offsets are +40 for the front +35 for the rear and I’m trying to come up with a tire combination that is as close to stock as possible. I don’t want to add spacers or anything and I don’t want to affect the xdrive any help would be greatly appreciated.
04-14-2021, 06:43 AM | #2 |
Rep 651
04-14-2021, 07:36 AM | #3 |
Rep 1,497
If you're after a flush look more than likely you're going to need to add spacers. With the sensitivity of the transfer case you have stay within 1% overall circumference of OEM wheels/tires. 295/30/R22 front 335/25/R22 rear. I don't think spacers will void your warranty and even if so simply yank them off before you take into the stealership for work.
04-14-2021, 04:27 PM | #7 | |
Rep 1,497
Depends! Are you m-sport, x-line, or luxury? I'm assuming all 3 trims come in the X6 as in X5. |
04-15-2021, 04:16 PM | #8 |
Rep 22
Im a m sport
04-16-2021, 07:04 AM | #9 |
Rep 1,497
Which means you have the flared wheel arches so more than likely you're going to need spacers for that flush look. Now if you're ok w/ them being sucken in a bit then no spacers required. I believe what you listed are the same offsets as my 22's and I went w/ H&R 15mm front and 20mm rear spacers and it's perfectly flush.
04-16-2021, 07:34 AM | #10 | |
Rep 51
04-16-2021, 08:30 AM | #11 |
Rep 22
How is it that you come of with percentages ? And what issues are you having with this set up? I’ve ordered my tires already with this set up trying to prepare for any issues. Researching spacers now which I tried to avoid
04-16-2021, 08:49 AM | #13 |
Rep 51
For the winter I had my 20 inch rims on, now I switched to 22s and started getting the ticking noise during the acceleration. I'm not sure if it's because of 22s but i will be putting back on my 20s to see if the problem goes away.
04-16-2021, 09:30 AM | #15 |
Rep 22
Thanks for the chart finally hit the correct tab new to this rim thing i usually just keep mines stock lol. Will the .4 cause issues not so much warranty I know to they won’t cover that but anything else that’ll cause a headache?
04-16-2021, 09:40 AM | #16 |
Rep 22
04-16-2021, 10:03 AM | #17 |
Rep 1,497
04-16-2021, 11:11 AM | #19 |
Rep 1,497
It will turnout great, just like mine did, but beware you'll prob not like the wheel/fender gap so be prepared to buy springs or coilovers in the near future. I've had my wheel/tire combo 1.5 yrs and just now getting around to coilovers. Can't wait to get them installed.
