04-19-2021, 12:31 PM | #1 |
Rep 571
Looking for ATL mechanic with bolt extraction experience
I was doing some suspension work and in the final stages of putting things back together I snapped 1 of the strut bolts that secure the reinforcement ring to the strut mount from the top of the tower. (picture will the yellow circles is for reference, not my picture but the bolt I snapped is the yellow circle on the right).
Of course shops don't want to provide an estimate for extracting it and I don't want to drop the car off and have them come back saying it's a 4 hour job when I know it's not, and then I'm also out the "inspection fee" for them looking at it. Any backyard mechanics in Atlanta interested in taking on this job for a reasonable price? DM me if so and thanks for your help.
"If you have everything under control, you're not moving fast enough"
04-19-2021, 03:48 PM | #2 |
Rep 3,549
Are you able to jam a flathead screwdriver in the top side of the broken stud and screw it out? You should be able to screw in or out since there's nothing blocking that stud on the bottom of the top mount.
If not, you can take the top mount out of the car (just like if you were doing a spring change), and then use a dremel to cut a flathead slot in the bottom of that stud that slightly sticks out of the bottom of the top mount and screw it out that way.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
Sahbatage503.50 |
04-19-2021, 04:17 PM | #3 | |
Rep 571
Also a good suggestion, I just fear taking it apart again cause I had so many issues with creaks and noises that I finally assembled it and everything was quiet.. but of course I had to ruin that by snapping a bolt.
04-19-2021, 04:52 PM | #4 | |
Rep 3,549
With how long it may take you to "figure out" how to do the first method, this might be faster. Once you get the stud out enough, you can use a pair of vise grips or channel locks to just grab the stud and spin it out if the screwdriver isn't catching very well.
Sahbatage503.50 |
04-19-2021, 06:04 PM | #5 | ||
Rep 571
04-22-2021, 06:56 AM | #8 |
Rep 2,147
Couldn't have said it better myself
YT: ntg44
04-22-2021, 12:28 PM | #9 |
Rep 571
They say they can do it, but won't commit to a reasonable time for repair and I know once I drop the car off I'm at their mercy and don't want to come back to a "4hr" job invoice.
04-22-2021, 12:32 PM | #10 |
Rep 571
[QUOTE=FaRKle!;27492421]I'd just take a hammer and see if you can create a small indentation, just enough to get a little bit of bite. It's unlikely you're going to ruin the threads unless hammering directly on them strongly.
Well I tried the hammer method today and it worked, sort of. I didn't use a lot of force at all but when I tapped a flathead into it a few times it popped out of the bottom, but also popped this piece out with it. I guess this is what the 5 strut mount bolts screw into, any idea if I need to reinsert this from the top or underneath? FaRKle!
04-22-2021, 01:22 PM | #11 | |
Rep 3,549
Sahbatage503.50 |
04-22-2021, 03:04 PM | #12 | ||
Rep 571
04-23-2021, 11:22 AM | #13 |
Rep 4,203
Well us 3 bot hat guys have been fine all these years.,...your probably good with 4
I would just take the other 4 out lower the whole assemply then spin it out with pliers |
04-23-2021, 02:13 PM | #14 |
Rep 571
I had the exact same thought! So I wasn't in a rush. I was finally about to pop out the broken bolt yesterday and replace it, I also replaced the other 4 just to be safe in case I over-torqued them too, compromising their strength without realizing it.
