04-27-2021, 10:31 AM | #1 |
Rep 35
Remove Tyre TPMS Warning - Can someone code for me via Teamviewer ?
Hello,
I have an 40e. I changed Tyres to 21". So nice ! But I get the TPMS error as they have no sensors in there. I have the soft (E-SYS), I have the ENET cable and latpop with Windows. Could someone do a Teamviewer and help me to code this please ? I can setup everything in the car so it is just the coding part... Very happy to pay 50$ for this support ! Thanks in advance Sam |
04-27-2021, 12:04 PM | #3 |
Rep 1,703
Drives: 2014 428i and 2018 X5
Why weren't the sensors transferred to the new wheels when they were being installed?
___________________ 2014 F32 428i M-Sport 2018 F15 M-Sport |
04-27-2021, 04:05 PM | #6 |
Rep 35
I was able to do some E-Sys coding for the first time
However, when I get down to the TPMS it is already unactive I did this with the bimmercode probably. But the alert keeps coming back. Any idea on how to remove it completly ? |
04-27-2021, 04:10 PM | #7 |
Rep 35
I found the "trick" in another post.
To desactivate TPMS In HU_NBT > 3001, code RDC to nicht_activ In HU_NBT > 3001, code RDC_SAFETY to nicht_activ In HU_NBT > 3001, code RPA to active Opposite to reactivate https://f30.bimmerpost.com/forums/sh....php?t=1061643 |
04-27-2021, 06:54 PM | #8 | |
Rep 108
04-27-2021, 10:36 PM | #9 |
Rep 265
Best and fast way is to vo code. Delete 2vb from vo and code. Kombi, nbt, icm and abs. This will automatically default to ftm.
I personally like tpms and I always end up retrofitting on all my vehicle. |
04-28-2021, 01:32 AM | #10 |
Rep 35
Thanks all.
I will check tonight. Your firest coding operation is always scary Charles.soori, what do you mean by retrofitting ? You install the module in each wheel ? Where do I get the TPMS sensors in case ? Is there a specific model and does it require coding (not the car but the sensors) ? |
04-28-2021, 05:14 PM | #11 | ||
Rep 7,584
Whereas the system that uses actual sensors in each wheel is called the RPA (direct tire monitor system)...aka TPM system You can tell by the coding parameters in the 1st two lines...the (direct) RDC system was coded to INACTIVE...and the 3rd coding line ACTIVATES the RPA (indirect aka FTM) system.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
CanadianLurker41.00 |
04-28-2021, 07:01 PM | #12 | |
Rep 265
Look in ebay you will be able to find all 4 tpms new for around 150usd |
04-28-2021, 07:02 PM | #13 | |
Rep 265
Coding just nbt is not enough to disable tpms. You need coding In abs and icm as well for sure. Best is vo coding |
04-29-2021, 04:28 PM | #14 | |
Rep 7,584
But you are correct that if you have something like ESYS...you need to do coding to multiple modules to change between the TPM & FTM systems.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 04-29-2021 at 04:43 PM.. |
05-01-2021, 10:06 AM | #15 |
Rep 35
Hello everyone, I did the change mentioned above and error came again. I did remove all errors and then it went away ! I did a little tour (2 miles max) and still no error. Let's hope this fix the issue.
Regarding the flat tyre, is it really needed ??? It is around 10 years it is common and only for luxury cars, low tiers dont have it and they survive very well. On top, I agree that if only a woman like mine was driving, she could be driving on 4 flat tyres all day long but most people can feel it and I do check 2-3 times a year that all is fine. Last question, I try to code in the BCD_BODY and got that cafd_000017be-071_010_030 was not found. I found it on the web but is it safe ??? Any risk to do something wrong if I use a wrong cafd ? It is exactly the same name. Any risk ? |
05-01-2021, 12:18 PM | #16 |
Rep 1,270
If you get a puncture on a run flat tire, it is not so easy to feel it... The sensors are handy for that, and also how often do you manually check that you have the right pressure in the tyres...
05-03-2021, 02:21 PM | #18 |
Rep 35
The solution isn't working... 15km after, error TPMS came back 😭 I have now ordered the sensors for the car and then I will get the installed.
Any idea on the bcd_body? Any risk when you download the cafd online? |
05-21-2021, 01:18 AM | #19 |
Rep 35
Hello! Finally! I got TPMS sensor on Ebay (Eur 130) got them installed for 100eur and then unprogrammed the change for TPMS with e-sys and boom all worked! Not as cheap as expected but all works well.
