05-04-2021, 03:29 PM | #1 |
Rep 46
Major sunroof leak
I got into my x5 after a heavy rainstorm and the airbag warning came up. I then noticed that my passenger side floorboards front and back were soaked. I’m talking 3 inches of water. Carpet is soaked horribly. The seat was soaked as well. Has anyone had any experience with this? What needs to be replaced or repaired to fix the airbag fault obviously caused by flooding water? This is super disheartening since I’ve had this car less than a month and it now it is likely going to require a major disassembly to dry it out.
05-04-2021, 03:39 PM | #2 | |
Rep 18
05-04-2021, 03:45 PM | #3 |
Rep 552
Drives: 2014 X5 35d, 2008 Lexus IS-F
Did you search this topic?
05-04-2021, 03:50 PM | #4 |
Rep 46
05-04-2021, 04:34 PM | #5 |
Rep 2,528
Contact your insurance company and bring the car to the dealership, 3 inches of water in the car is not something you can casually dry up, this is pretty much flood damage.
05-04-2021, 05:21 PM | #6 | |
Rep 552
Airbag got wet from the leak. Get a steak cleaner with a hand attachment so you can suck up all that water. Disconnect battery, wait 10 minutes, take of the airbag and inspect to see what is wet, let it dry, dry of all terminals, reconnect everything, and try to clear the code. If it doesn't go away, then go to the dealership. Or you can skip all the DIY and go to the dealership. Also, less than a month… you should be talking to the person/people whom sold it to you. |
05-04-2021, 05:23 PM | #7 |
Rep 46
05-04-2021, 05:25 PM | #8 |
Rep 46
05-04-2021, 05:56 PM | #9 |
Rep 552
05-04-2021, 06:08 PM | #10 |
Rep 1,211
The exact same thing happened to me. Mine was still under warranty, so dealer took care of it. It was the sunroof drain tubes, as stated. They pulled both fenders off to straighten the drains. My airbag light was on, too - and the seat heater didn't work. They pulled everything apart to dry it out and it has been fine since.
My dealer knew exactly what they needed to do. This is a common problem with F15s. I don't know if its a design flaw or a manufacturing defect, but its one or the other.
2017 X5 35d (Performance Center delivery March 2017)
2019 230i X-drive 2022 M3 base 2000 328i sedan (UUC suspension - still the favorite), 2006 M3 slick top - Alpine White/Cinnamon SOLD! 2008 E90 M3 SOLD! 1991 325iX (both great), 2019 Miata RF - various others not as memorable but gone. |
05-04-2021, 06:29 PM | #11 |
Rep 18
Talk to the dealership. There is a class action lawsuit on this issue. I had the same issue with a 2014 F15 within 2 weeks and the dealership took care of it.
05-04-2021, 08:35 PM | #12 |
Rep 46
What did the dealership do? I also can’t find anything about a class action suit regarding sunroof drains. I love this vehicle but can’t trust it anymore. I paid $31k for a used car because I was wanting a break from working on broken shit. I get that BMW needs more care but a car full of water is beyond unreasonable on a car with 27k miles. I love this car but I might be going a different direction after this.
05-04-2021, 08:50 PM | #13 | |
Rep 18
Google BMW sunroof leak lawsuit. |
05-05-2021, 10:12 AM | #14 |
Rep 41
It seems like the sunroof seals are also a possible cause of this issue. While they aren't meant to provide a 100% seal, and the drains are frequently involved, when I recently bought a CPO 2017 X5, very low miles, the sunroof seal was all but completely deteriorated. Thankfully no water issues yet, and I had the dealer replace it under CPO warranty. You all are making me want to scope the drains though and make sure they are clear.
Mark |
05-05-2021, 11:50 AM | #15 |
Rep 334
I tried to run some string trimmer line down mine last night, but both sides seem to block at 6-7 inches in. Dumped water through, runs fine and drains fine. No major backup observed at the entrance. May borrow the bore-scope from work and see what I can see.
Will mix up some hot water / bleach in a 10:1 and run it through to clear what I can out. |
05-05-2021, 12:17 PM | #16 |
Rep 630
We got torrential rains here in South Texas over the last week. Originally had our F15 parked nose down. Passenger side floor board got damp (I went out in the storm to check it). Looked like water was filling up the door and overwhelming the door drains. But I am definitely going to pull the A-pillars and look at the sunroof drains.
After seeing that the floor was damp, I moved the car so that the nose was up. Seemed to alleviate the ingress of water. So, either the doors got overwhelmed (we had multiple inches of rain in less than an hour) or the front drains are kinked and/or clogged. Seems BMW can not get the drains for a panaramic roof correct on their product line. Literally every single model since introduction has had this problem. E53, E61, E70, F15, etc, etc. Anything with a pano roof. It's stupid that this is still a problem and that they continue to put electronics in locations that are known to cause issues because of the sunroof drains. What's the definition of insanity again? And I am a hardcore BMW addict saying that... |
05-05-2021, 01:22 PM | #17 | |
Rep 97
2018 X5 35i
05-05-2021, 09:08 PM | #18 | |
Rep 46
05-06-2021, 08:04 AM | #19 |
Rep 301
No leaks in my car yet but I am fully prepared to pull the sunroof fuse and have the roof fully vinyl wrapped at the first sign of water in the car.
The crazy amount of heat radiating through the glass helped in that decision too. |
05-06-2021, 10:56 AM | #20 | |
Rep 630
Sorry for the blurry pic on this one, forgot to focus phone. But there are two drains in the door, one at front and one at the rear. You can see here there is actually debris in our front drain partially blocking it. So turning the truck around at least allowed the water to get to the rear, unblocked drain. I think water actually flooded up the door and exited at this point. Can someone confirm if that gasket is supposed to be inserted in that opening? It certainly looks like it. This F15 was involved in a hit on the passenger side involving the front fender and possibly front door. Maybe the body shop did not insert the gasket? I have found other things they did not do properly (missing push pins, 8mm fasteners, and rivets). At least they did a good job on panel gaps and the paint work. This is where I saw and felt water. I did not find it any higher than these points. Nothing down the a pillar, headliner, on seats, etc. It was a crazy amount of water falling. About 9 inches in 4 days, with some periods of an inch or more an hour. It was during one of those periods that I think that the door got overwhelmed. Does my door flooding theory sound plausible? Anyone else have this problem? I have yet to pull the A-pillars off to check the drains but I will. |
05-06-2021, 09:48 PM | #21 | |
Rep 46
05-06-2021, 09:50 PM | #22 | |
Rep 46
