05-17-2021, 03:22 PM | #1 |
Rep 201
Rear Damper Mount Orientation
Those of you with aftermarket rear coils/dampers - I personally have MCS-1 ways. How did you mount your rear dampers? Shaft pointing up or down into the lower control arm, and why? I know it can't be done either way, but I was wondering if there were some opinions on anything specific I'm not considering.
05-18-2021, 10:01 PM | #2 |
Rep 940
You need to mount it right side up or it will hit the sway
F80 M3-DCT MaxPSI CH, BM3 with F80 Paul E85 and Custom Rom track tune MCS 2Way Remotes
Signature SV104 E46 M3 F85 X5M https://www.instagram.com/fastmacm3/ |
rborane241.00 |
05-22-2021, 04:07 PM | #3 |
Rep 1,917
MCS 2WNR on my M2C. H&R sway.
Mine is not inverted and makes use of spacers for sway clearance, although my ride height isn't too low.
Matt
05-22-2021, 05:49 PM | #4 |
Rep 295
05-22-2021, 10:18 PM | #5 |
Rep 940
That is a 6" 600lb
melanthius255.00 |
05-23-2021, 11:08 AM | #6 |
Rep 1,917
It's a 6" 450 lb
Matt
05-24-2021, 11:11 AM | #7 |
Rep 201
This is what I did, the body doesn't sit to close to the sway bar and I noticed it is how BMW did it from the factory - also keeps the adjustment knobs clear of road debris damage.
05-28-2021, 10:42 AM | #8 |
Rep 871
Ohlins ttx, non inverted. Nothing has touched on my car either regarding the sway bar or spring to the body.
2.25", 800lb, 6" (7" maybe, I'd have to double check) with helpers. |
05-28-2021, 10:50 AM | #9 |
Rep 855
05-28-2021, 11:46 AM | #10 | |
Rep 871
