05-22-2021, 05:15 PM | #1 |
Extraordinaire
Rep 382
Can my N63 TU 650i always sound like it does during cold start?
I've got a Meisterschaft on my 650i and during cold start it sounds loud and mean (which I LOVE!).
Is there a way that the same exhaust note/sound can be made to stay even after cold start is over?! Thanks! |
05-22-2021, 09:21 PM | #2 |
Rep 285
Go with catless downpipes and intakes. It will always sound like it should then.
2015 Bmw 650i xDrive Gran Coupe
M Sports Edition Carbon Wing Carbon Front Splitters Carbon Rear Diffuser Carbon Grilles Powder Coated 373m Triple Bronze CPG intakes Arm catless downpipes Arm charge pipes Custom Snow Performance methanol injection Custom exhaust, straight pipes to quad tips Bootmod3 Stage 2 3.5 Tmaps xHP Stage 3 |
05-25-2021, 12:01 PM | #3 |
Extraordinaire
Rep 382
05-25-2021, 12:41 PM | #4 |
Rep 741
05-29-2021, 12:38 AM | #5 |
Rep 239
The zip tie method keeps the flaps open, but it does not make the car sound like a cold start every time. My valves are zip tied but it still only "cold starts" when its cold.
2014 BMW 650GC M sport
2011 BMW 550i M-sport/AW 1991 Nissan 300ZX Twin Turbo 2007 Chevrolet Corvette Z51 (sold) 2001 BMW 325ci (sold) |
05-29-2021, 04:10 PM | #6 |
Rep 741
I could be wrong but I think only two things happen in a cold start. The engine idle speed is kicked up for 30 to 40 seconds and the exhaust flaps are opened.
05-29-2021, 08:14 PM | #7 |
Rep 2,352
This may not be valid on N63 cars but I suspect it is the same. On S63Tu cars the turbo wastegate flaps are completely open to get as much heat as possibly into the Catalytic Converters. Once they are up to temp the wastegate flaps shut which coincides with the rpm reduction back to normal idle level.
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
05-29-2021, 08:33 PM | #8 | |
Rep 632
Drives: 2014 M6 Grand Coupe CP
quote: The purpose of the secondary air system is to perform exhaust re-treatment during the engine warm-up phase. During this process, fresh air is blown directly into the exhaust manifold thus increasing the rate at which the catalytic converter is heated (thermal post-combustion of exhaust gas) end quote This might contribute to the loader sound during that initial cold start
F06 M6 Grand Coupe CP
Sapphire Black Metallic The drive is the destination |
05-29-2021, 09:36 PM | #9 |
Rep 404
Bootmod3 lets you choose when the exhaust flaps are open. To be fair, it wont always sound like a cold start, but i have mine set up so that in sport or sport plus the exhaust valves are 100% open, but in comfort they follow the factory settings. That way the exhaust is loud when i want, and quiet when i dont. I did fit the M6 mufflers though, so it is always a bit louder than stock.
If you are running aftermarket exhaust with out the valves, as others have said, catless down pipes are what you are looking for. |
05-30-2021, 02:32 PM | #10 |
Rep 84
No option to keep the sound of the car like during cold-start while idling.
I have even asked custom tuners if this would be a valid options but no one is able to do that. I think the cold-start table is hard-coded, you cannot change the duration or the behaviour (like cold-starting again with the engine at temperature). You can only enable or disable this feature and set the rpm (with bm3). As mentioned, the car runs slightly rich in cold-start. Also no one is able to increase the rpm idle (the lovely sound you are hearing is the sweet-spot between 1500 and 1800 rpm when there's a little bit of drone. Would be great to have this rpm range as the normal idle (just from an acoustic stand point, not sure if it does stress the engine) |
06-02-2021, 05:04 AM | #11 |
Rep 76
I thought the cold start sound was down to the EGR valve (exhaust gas recirculation valve) recirculating exhaust into the inlet manifold until the engine temperature reaches the required level....
