06-01-2021, 10:00 AM | #1 |
Friends don't let friends ESS
3224
Rep 888
Drives: '11 Lemans Blue 6mt Harrop e90
Garage List 2011 E90 M3 [9.00]
2003 Porsche 911 Turbo [9.75] 2019 BMW X5 xDrive40i [0.00] 2013 Mercedes E550 ... [0.00] |
DCT pan with 1 bolt missing.....
I serviced my DCT over the weekend, changing the fluid, suction filter, pan, and bolts. The bolts are tightened down to 7 N/m. Either my torque wrench failed or one of the new bolts was shit, because I sheared a bolt on the passenger side of the transmission off. While I await a proper sized bolt extractor, the pan is holding fine with no sign of leaks after several hour long spirited drives. Makes me wonder whether how quickly I need to get to it.
I can't be the only person to have done this and wonder anyone's thoughts on how long I could expect the new pan and gasket to do its job with a bolt missing. |
06-01-2021, 10:45 AM | #2 |
Rep 705
Those bolts are indeed fragile.. fortunately they were in stock at my local dealer (so cal) so no need to order online and wait for shipping. I can't comment on how long its going to hold up, but if you can pick it up at a local dealer it'd be an easy fix.
06-01-2021, 04:47 PM | #4 | |
Rep 954
7nm is at the bottom of my 1/4 inch drive inch-pound torque wrench and I simply don't trust it that low. Just snug it up and call it good. Maybe come and check it in a week or so, just to be sure.
Gossypiboma543.50 M43S7RO504.00 |
06-01-2021, 07:17 PM | #5 |
mTekMods
2169
Rep 2,922
Use a torque wrench on all hardware which has a specified torque rating, the purpose of the 7NM on the pan is to spread the force equally throughout the sealing surface. Diy guys should invest in a good torque wrench and have it calibrated every two years depending on how it’s used.
MilehighM3915.00 |
06-02-2021, 01:30 PM | #6 | |
Rep 1,196
I've never seen a forum more concerned with tq. values for every fastener than this one, its almost comical. To each their own though.
06-02-2021, 06:42 PM | #7 | |
Rep 1,055
Agreed, I use a meter to tie my shoes to spec.
Gossypiboma543.50 |
06-03-2021, 01:17 PM | #8 | |
3224
Rep 888
Your point is well taken, though. I've never worried much about torque working on other cars. That said, this car with it's high revs, aluminum block, aluminum screws, use of plastic or other alternative materials in various areas does raise the bar for torqueing to spec. |
DrFerry6734.50 |
06-06-2021, 10:54 AM | #9 |
3224
Rep 888
All is well. I used a bolt extractor kit and pulled the broken bolt out this morning without any damage to the pan. I'm not sure what material these bolts are - tungsten? - the bolt shaft was very hard to drill into even with a 1/16" titanium bit. Thankfully the shaft wasn't broken off flush with the transmission housing, because the extractor seated between the broken shaft and the aluminum sleeve and that was enough to back the broken bolt out by hand. The sleeve popped right back into place and I hand tightened a replacement bolt back into place, plus another 45 degree turn.
To answer my own question, the transmission was not leaking any fluid around the missing bolt position but the pan was not seated snug against the transmission housing. I think left unaddressed, it would have eventually started weeping. Cheers everyone. Thanks for your input. |
DrFerry6734.50 |
06-07-2021, 05:29 AM | #10 | |
mTekMods
2169
Rep 2,922
https://www.tekton.com/torque-wrench-bundle-trq99901 its not really being overly concerned, the majority of people come here asking how to do a job, why not do it properly?
2011 Frozen Black/Fox Red E90 M3 650+WHP
G-Power Supercharged First DCT to Manual Conversion Worldwide KW CS, BBS RI-A, BW Headers, Snow 2.5 |
