06-14-2021, 01:30 PM | #1 |
Rep 599
Vehicle Check Indicator
Just purchased our cpo 2018 x5 back in March. It's service indicator says it's now due for oil and a vehicle check. I looked into that service and saw that some people pay and some don't. I'm 2 months outside of my 3/36k maintenance. Shouldn't the vehicle check been cleared when I purchased it in order to of made it CPO? Thanks for any I sight.
06-14-2021, 01:51 PM | #2 | |
Rep 3,658
If it just showed up now, service is due or the dealer forgot to reset the service intervals. Unless they didn't do any service as part of the CPO certification process... it's possible it didn't need much? If the vehicle doesn't need an oil change, and it likely doesn't need a vehicle check if it just went through the CPO certification, you can reset/turn off those warnings. Just Google it, lots of info on it. If an oil change is due, I'd ask the dealer to take care of it as it probably should have been done in March if it was that close to being due. Unless you've piled on 1000's of miles since March. |
06-14-2021, 03:37 PM | #3 | ||
Rep 599
06-14-2021, 05:03 PM | #4 | |
Rep 383
06-16-2021, 10:44 AM | #5 |
Rep 7,586
None of the service due warnings should be a surprise. You get warnings prior to the service being due…and at the least…you can simply go into iDrive and see the listed services…and as you scroll through them, you can see the date & mileage when they come due. (the brakes may still be an estimate and will keep extending if you have reached the wear sensor)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
